Baofeng gt3-wp scan
rloc
Hi all, first post to this forum.
I recently purchased the 3WP and I have a scan problem different to those noted above.
I want to scan ONLY my programmed channels but the radio scans the entire VHF or UHF band in the channel increments I have selected.
Is it possible to set the radio up to program only memorized channels?
I don't have a programming cable so I would need to do this manually.
Thanks all
r_eugene1
Southwest Ohio
Thanks all
Yes. Just make sure that you are in the "Channel" mode not the "Frequency" mode. If you have you radio in the frequency (VFO) mode it will scan the VHF or UHF bands. I have the GT-5TP and mine scans fine in the channel mode.
rloc
Thanks Randy-unfortunately this doesn't work. The scan function seems to be disabled in Channel Mode.
Do I maybe need Chirp software to get this working?
jonwienke
More Info Coming Soon!
VA
Scanning is enabled on a per-channel basis, so that when you're scanning you skip things like the NOAA weather channels that broadcast continuously.
Definitely use CHIRP rather than the factory crapware, and the scan enable is the far right column labeled "Skip". If there is an S in the column, the channel will not be scanned.
