so here is my problem i really like the UV-82HP and ideally that is the HT i'd want to get BUT big problem, this is for backpacking and there are NO portable charging options for this, as an example the Cobras i have right now charge off of a battery pack through a usb cable..very convenient
SO...here is my question, can i adapt the AC charger base somehow to work with my battery pack? it outputs 5V 9V 12V 16V 19V 20V DC, i was thinking the 9V setting would work if i had the wiring done correctly?
another option im looking at is getting the BF-F9 with the extended battery which has some kind of barrel plug hole on the side of the extended battery which may or may not work with 9V from the battery pack considering that the stock charger outputs 10V
anyone with experience on this?
