Baofeng Baofeng UV-K6 programming software
MaxDonoghue
Kingston, ON
Picked one of these up off AliExpress for $29. Can't seem to find any programming software for it. Tried the Quansheng UV-K6 software but it didn't recognize the radio. Anyone using one?
MaxDonoghue
Kingston, ON
I've downloaded the latest version of Chirp, the Baofeng UV-K6 is not listed. I tried Quansheng UV-K6 and no go. I tried every radio listed under Baofeng and nothing. It did work fine with my Tidradio TD-H3 so I know the cable is good.
merlin
DN32su
If you can get Chirp to work, it is popular.
Your radio is Baofeng, different fimware than Quansheng. Try Baofeng software.
I never could get Chirp to work with either radio.
Maybe select UV-5R from the list and see if it connects.
gringoing
Hello, I have made success in the programming of my UV-K6!
Out of curiosity, I messaged the seller on AliExpress asking for the CPS if they had it available. The reached out with a rar file (which I reluctantly ran) but it has worked flawlessly. If you would like, I can upload it to my dropbox and share a link.
Good luck.
-Austin
chuck55
TN
Hey Austin
I also have one of the Baofeng UV-k6 and need the software. If you could upload it I would appreciate it.
TIA
Chuck
gringoing
Baofeng UV-K6 CPS
Please find the link to the install rar file above. It will take you to a DropBox. The file install wizard is all in Chinese but the final software is in English. Use Port 6 for connecting to your radio via USB. Good luck and if you have questions, reach out and I'll answer the best I can.
-Austin
-Austin
The PORT number will vary depending on one's computer and what is in use.
chuck55
TN
Hey,
Thank you so much, I was able to download it. I need to move it to a windows machine and will then try it out.
Chuck
K7HAD
San Tan Valley
The manufacturers software is now available from their support website. Don’t be to surprised by its featureless design. Copy/paste functions not available. Software will also not allow programming of air band frequencies. Air band frequency programming can be accomplished though the keypad but is anything but effortless. When programming from keypad you cannot overwrite an existing channel, you must delete it’s contents first before the radio will allow you to write to that channel. Hope my comments help someone make a better decision.
h_milsom
England
Hi - I have a newly purchased Baofeng K67 PRO despite my best efforts with all the available CPS (using a cable that works well with other radios) I have not managed a connection; after a short wait I get a "failed"message.
Any thoughts as to why?
Many thanks ...
h_milsom
England
BAOFENG_K6_CPS_1.1.2 and I've tried (as has been suggested) UV-K5 but still no go
Cable is Baofeng K-type from different suppliers - all the same
K7HAD
San Tan Valley
The CPS I use is the Baofeng UV-5RH Pro and an FTDI programming cable. I have verified this works for both the K61 Pro and the K67 Pro. I have both models and they work fine with this CPS with one exception. Any and all "Airband" programming will have to be done by hand using the keypad. There is no CPS currently available for these radios that allows programming of airband frequencies. 73 de K7HAD.
h_milsom
England
Unfortunately no - "Failure!" again ... but I will try with another type of cable ...
Another FTDI cable ordered.
IamEncrypted
h_milsom
England
Success! Baofeng UV-5RM PLUS GPS works ... complicated but working my way through it ...
Craigmoe
S.W. Michigan
Purchased programming cable for the K6 off the Baofeng site and downloaded the software from same.
Constant 'failed' when trying to read radio. Any further suggestions? Radio seems to program just fine
manually. Purchased for the tri-band capability. Thanks much... C
K7HAD
San Tan Valley
What are the chances that you can take a picture of the Data sticker under the battery and post it here. That way we can eliminate any model confusion. I have the K5, K6, K61 Pro and K67 Pro and all have worked flawlessly with the right cable and CPS. And chirp does have both the K5 and K6 in their lineup under Baofeng. No one has come up with or produced ANY CPS application that allows programming of all the features on the K61 Pro or K67 Pro. It takes alot of manual programming to get these two models to work correctly. Anyway, I look forward to seeing the model on the data sticker. And will advise once posted.
