Bayshore Mall System
DaveH
Ottawa, Ont.
How to tell if DMR frequency is simplex or repeater input:
(1) By frequency sub-band (usually)(more later).
(2) DSD+ shows MS (Mobile Station) for simplex/inputs, or BS (Base Station) for outputs.
(3) Listen to sound on analog receiver (all tones/decoding turned off). Simplex/input
has a rapid pulsating sound; only one TS transmitted. Repeater output is continuous grinding sound,
both TS's always transmitted even if one is idle.
Dave
DaveH
Ottawa, Ont.
I cannot leave a TimeSlot empty. When a submission arrives without that data, I am forced to list it as SL* (Wildcard) until that information is submitted, otherwise it won't list.
Understood, just suggesting that the sourcing end needs to figure it out.
Dave
fmoore
Ottawa, Canada
So, In response to DSD+Event file information: This all was recorded when monitoring 461.73750
2020/02/21 17:57:44 Group call; Slot=1
2020/02/21 17:57:47 Group call; TG=41 [Bayshore Mall Security] RID=4 [Bayshore Security Dispatch] Slot=1 7s
2020/02/21 17:57:56 Group call; TG=41 [Bayshore Mall Security] RID=340 [Security Unit] Slot=1 3s
2020/02/21 17:57:59 Group call; TG=40 RID=7414083 Slot=1
2020/02/21 17:58:04 Group call; TG=41 [Bayshore Mall Security] RID=340 [Security Unit] Slot=1 3s
2020/02/21 18:21:52 Group call; TG=41 [Bayshore Mall Security] RID=340 [Security Unit] Slot=1 1s
2020/02/21 18:21:55 Group call; TG=41 [Bayshore Mall Security] RID=4 [Bayshore Security Dispatch] Slot=1 1s
2020/02/21 18:21:57 Group call; TG=41 [Bayshore Mall Security] RID=340 [Security Unit] Slot=1 4s
2020/02/21 18:22:11 Group call; TG=41 [Bayshore Mall Security] RID=340 [Security Unit] Slot=1 1s
2020/02/21 18:22:17 Group call; TG=41 [Bayshore Mall Security] RID=4 [Bayshore Security Dispatch] Slot=1
2020/02/21 18:22:18 Group call; TG=41 [Bayshore Mall Security] RID=340 [Security Unit] Slot=1 1s
2020/02/21 18:22:20 Group call; TG=41 [Bayshore Mall Security] RID=321 Slot=1 1s
2020/02/21 18:22:22 Group call; TG=41 [Bayshore Mall Security] RID=340 [Security Unit] Slot=1 3s
2020/02/21 18:22:28 Group call; TG=41 [Bayshore Mall Security] RID=321 Slot=1 1s
2020/02/21 18:22:31 Group call; TG=41 [Bayshore Mall Security] RID=340 [Security Unit] Slot=1 2s
2020/02/21 18:22:38 Group call; TG=41 [Bayshore Mall Security] RID=321 Slot=1 1s
2020/02/21 18:22:42 Group call; TG=41 [Bayshore Mall Security] RID=340 [Security Unit] Slot=1 1s
2020/02/21 18:28:53 Group call; TG=42 [Bayshore Mall Cleaners] RID=1 [Maintenance/Dispatch] Slot=2
2020/02/21 18:32:42 Group call; TG=42 [Bayshore Mall Cleaners] RID=1 [Maintenance/Dispatch] Slot=2 2s
2020/02/21 18:32:46 Group call; TG=42 [Bayshore Mall Cleaners] RID=1 [Maintenance/Dispatch] Slot=2 1s
2020/02/21 18:38:35 Group call; TG=41 [Bayshore Mall Security] RID=321 Slot=1 1s
2020/02/21 18:38:38 Group call; TG=41 [Bayshore Mall Security] RID=331 [Security Unit] Slot=1 1s
2020/02/21 18:38:40 Group call; TG=41 [Bayshore Mall Security] RID=321 Slot=1 5s
2020/02/21 18:38:48 Group call; TG=41 [Bayshore Mall Security] RID=331 [Security Unit] Slot=1 1s
2020/02/21 18:47:45 Group call; TG=42 [Bayshore Mall Cleaners] RID=1 [Maintenance/Dispatch] Slot=2 1s
2020/02/21 18:48:24 Group call; TG=42 [Bayshore Mall Cleaners] RID=1 [Maintenance/Dispatch] Slot=2 5s
2020/02/21 18:48:32 Group call; TG=42 [Bayshore Mall Cleaners] RID=1 [Maintenance/Dispatch] Slot=2 2s
2020/02/21 18:48:36 Group call; TG=42 [Bayshore Mall Cleaners] RID=1 [Maintenance/Dispatch] Slot=2 3s
2020/02/21 18:48:43 Group call; TG=42 [Bayshore Mall Cleaners] RID=1 [Maintenance/Dispatch] Slot=2 1s
2020/02/21 18:49:59 Group call; TG=42 [Bayshore Mall Cleaners] RID=1 [Maintenance/Dispatch] Slot=2 1s
2020/02/21 18:50:09 Group call; TG=42 [Bayshore Mall Cleaners] RID=1 [Maintenance/Dispatch] Slot=2 9s
2020/02/21 18:50:20 Group call; TG=42 [Bayshore Mall Cleaners] RID=1 [Maintenance/Dispatch] Slot=2 4s
2020/02/21 18:50:26 Group call; TG=42 [Bayshore Mall Cleaners] RID=1 [Maintenance/Dispatch] Slot=2
2020/02/21 19:00:29 Group call; TG=41 [Bayshore Mall Security] RID=203 [Cleaner] Slot=1 1s
2020/02/21 19:00:31 Group call; TG=41 [Bayshore Mall Security] RID=331 [Security Unit] Slot=1 4s
2020/02/21 19:00:38 Group call; TG=41 [Bayshore Mall Security] RID=331 [Security Unit] Slot=1 1s
2020/02/21 19:00:39 Group call; Slot=1
2020/02/21 19:00:41 Group call; TG=41 [Bayshore Mall Security] RID=203 [Cleaner] Slot=1
2020/02/21 19:14:32 Group call; TG=41 [Bayshore Mall Security] RID=331 [Security Unit] Slot=1 3s
2020/02/21 19:14:41 Group call; TG=41 [Bayshore Mall Security] RID=4 [Bayshore Security Dispatch] Slot=1 1s
2020/02/21 19:15:29 Group call; TG=41 [Bayshore Mall Security] RID=4 [Bayshore Security Dispatch] Slot=1 4s
2020/02/21 19:15:36 Group call; TG=41 [Bayshore Mall Security] RID=321 Slot=1 1s
I hope this helps narrow things down.
fmoore
Ottawa, Canada
Notice anything about TG versus Timeslot ("Slot")?
Dave
Dave,
Can you clarify your question?
I see that Slot 1 is used by Security and another Unidentified TG=40 user and Slot 2 is used by the cleaners. Or is this what you are pointing out?
Frank
DaveH
Ottawa, Ont.
Dave,
Frank
Just pointing towards some TGs only active on one TS, not both. The way the DB works with "*" it
implies both (or unknown). I check TG activity for a "reasonable" amount of time and if it's only
on one TS, that's the one...makes the DB more accurate.
Good work BTW, getting going with DSD+. It has a bit of learning curve, nothing radical. In a city
of a million people I count less than a half dozen people running it, who are regularly on here.
Dave
