BC250 update
garys
Central Texas
I updated my BC250Pro software to work with the new RR Web Service. Works fine, except that when I close the program I get a message telling me that BC250 has encountered errors and needs to close. Everything else seems to work fine.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Does ARC250 support rebanding for the 296/796? I'd like to add this software to the list in the wiki....
73 Mike
garys
Central Texas
I'm pretty sure it does, but I wasn't looking at that with this update. I was interested in the RR import issue. I'll try to remember to look at that when I get home.
lebrunmn
Retired... Get off my lawn!
Hampshire County, WV
I have the same issue...
Garys-
I'm having the same error msg issue... also, it's not communicating to my 796D on a port that I know is correctly configured. Gommert released an update to his ARC396 software yesterday, which fixed a similar problem with that software, so I'm hoping we'll see an update on the ARC250, soon.
I guess this info may not be much help, but at least you know that you're not alone...
Regards,
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Garys-
Regards,
ARC250 V1.21.01 has been out for a couple of days.
fmon
Eclipse, Virginia
73 Mike
I don't see anywhere for reband in ARC250 though in Software Setup a Custom Band Plan option is available, however, I think that option has been available for 6 1/2 year life of the software.
fmon
Eclipse, Virginia
If that is a Microsoft popup, I get it also.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
The key, AFAIK, is to have a bank type of 'Mot 800 Custom/Reband' or something similar. If it doesn't have it, then it's not capable of rebanding.
Too bad, but ProScan does cover it, so it's not a total loss. Thanks Frank
73 Mike
lebrunmn
Now I'm confused...
I'm actually running V1.21.02... not Build 1.
I thought that Build 02 was the original fix for the SOAP interface to RR--there havn't been any other ARC250 updates since then.
Do you recommend reverting back to Build 1?
Regards,
fmon
Eclipse, Virginia
Regards,
Hmm, I just now re downloaded and still get build 1. Current ARC433 is v1.21 build 2.
lebrunmn
OK, now I get it...
Frank-
Sorry for the confusion... OP, Garys was talking about ARC250PRO and I have ARC250BASIC... I just checked ARC250PRO, and you're I right, the latest Build is 01. But... on the BASIC verson the latest build is 02... go figure.
Garys-
Are you able to connect to your scanner with ARC250PRO? I can live with the Windows message, and would willingly upgrade to the PRO version, if I could just connect with the scanner.
Thanks guys,
garys
Central Texas
Frank-
Garys-
Thanks guys,
Yes, to test that I read out my 796D last night after I installed the update. In fact, I've tested connectivity and the RR import on 996XT, 396T, BC15, and 796. I use BCTool for my 330T and haven't hooked up my 996T since this all started.
Yeah, I have too many scanners! :)
lebrunmn
Still stumped... will check with Gommert
Gary, Frank-
Thanks for the back and forth tonight... I'm still dead in the water trying to get ARC250Basic to communicate with my scanner. I even downloaded the PRO version to see if that would help, but no dice. The RR SOAP interface works fine, but for some reason, I can't get the software to detect the scanner. I've checked the port a dozen times. I'll drop Gommert a note to see if he has any ideas or if a fix is in the works. I had the exact same problem with the intial update on the ARC396Basic software, and that was fixed with an update.
Take care,
