BCD396T Startup Configuration ? ?
safetyobc
South Arkansas
I was just curious if it would be possible to add this feature to the 396 via firmware upgrade. I think it is an awsome feature that is said to be on the BCD996T. It would be cool to have on the 396. Is it possible? Do you think it will actually happen?
jpm
What does it do? Sorry if this is a stupid question.
safetyobc
South Arkansas
Is in the wiki but so everyone knows what I'm talking about here is what is written there:
Pressing a number button while powering on the scanner automatically unlocks all systems assigned to that startup key and automatically locks all systems assigned to a different startup key (unassigned systems are not affected).
hiegtx
Mentor
Dallas, TX
From what I've read of it, it's sort of like a selective boot-up on a pc This is my guess as to how it would work, which may, or may not, be on target.
For my 396, I have several saved configurations on the pc. One for normal 'home' listening, one for weekday commutes, one for when I visit friends about 100 miles west, others that isolate certain agencies or systems..
So, in the various configurations, there are some systems that I can't pick up at all from where I am at that time. Why waste time scanning them? With selective configuration, they'd already be loaded. You'd just choose which config you wanted to use at that time. The other systems would still be loaded, but no time lost checking to see if a control channel could be found or a conventional signal picked up.
For somebody working between two different geographical areas, start the scanner with the systems loaded for where you are today. Tomorrow, boot it up with a different mix of systems, close call settings, etc, because you're in the alternate location 150 miles away. Without having to stop and reprogram the scanner via the pc.
This might also give you an option to set up a 'disaster' config. Heavy on FD, mutual aid, EOC's, in case of a major fire or other incident. Quicker to get that up & going via a custom config than trying to lock out the extra systems and talk groups that you have to do now to focus on one large event,
Steve
