bcd396t
towho
Alliston ON.
Hello
I have a question more of a help question. I programmed my scanner to listen to OPP.
I have static before and after a transmission and sometimes it seems to get stuck after they talk and stays static. My question is why. I have all the control tower numbers it all three band plans. Is there a way to tweak them
greggk
York,PA
Hello
What is OPP?
This is a pretty basic answer, but just a thought. Do you have the squelch turned up far enough? This has happened with me before as well when I had the squelch turned down as absolute low as I could go.
FWIW
Greg
wtp
Port Charlotte FL
my 396t
i keep mine at 2
if you put it that low does it cause more problems?
with p-25 you can fine tune it by pressing the function pad (left top) and puch down on the top knob twice, you will see squelch and the the automatic adjuster for p-25.
n4yek
Newport, Tennessee
towho
Alliston ON.
Thanks everyone for all your input. It makes no sense to me. I programmed the Edgar tower and duffel nottawasga talk group and it works fine.
Program the primrose tower and nottawasga talk group and the static comes back. I am at a loss.
WA0CBW
Shawnee Kansas (Kansas City)
You may have some local interference on those frequencies that raises the noise floor. Program those frequencies as conventional and see if you can squelch out the noise. If not then you may have some local interference.
BB
