JH2184
How do you adjust the P25 threshold on the BCD396XT?
You do have some control over the P25 adjustment... If you press and hold the "hold" button and turn on the scanner the screen will flash colors and allow you to get into the P25 settings. Then press menu and go to settings and then go to P25 adjust level. You will notice it is set to 50 for the default auto setting. If you change it to 200 (press 200 enter) now the default level will always be 8 and if you change it to 100 the default will be set to 11. You can check this when scanning by pressing Func then volume, Func then volume to watch the threshold. Auto works well for me but setting it to 200 isn't bad because most of the digital systems level off around 8 using the auto setting anyway. If you find that the default setting works best just set it back to 50 by pressing 050 enter.
Mike
I did what you stated about and I was adjusting the p25 adjust settings. I set it at 200, but when I check the screen to monitor the err rate it still says "8 Auto" is that what the unit is supposed to be reading. I thought 50 was auto?
Interesting... I also tried this on my 996XT and it seems to be the same. I have a question tho... What is P25 adjust "mode"? It seems to adjust from 0-15.
Correct me if I am wrong but I believe that value has nothing to do with the decode levels. I was always under the impression that this value represented the mili volts of the incoming signal needed to have the scanner begin the auto adjust threshold. Meaning the higher the number, the stronger the signal required for adjustment. This is set so if you are in a fringe coverage area with digital pixelation the scanner will not run a correction algorithm thus changing the level it already detected to be the best level.
The wiki has an extensive article on the subject...
P25 audio decode level adjustment - The RadioReference Wiki
73 Mike
Mike
This sounds by far the best explanation I have yet to hear for poor P25 reception. I live in the middle of the county system I am trying to listen to and have nothing but trouble. What I have noticed after many observations is that whan the outdoor humidity rises my reception improves to a point when it rains, everything goes to 100% including voice reception. I have a high end yagi on a rotor and it dosent seem to matter where I point it. Maby someone can explain the anomally with the rain and there would be some wiring/electronic fix for this. I have tried many different pre-amps, filters, indoor antenna setups. They might as well go ENC for all I have done with very little luck. Pray for rain.There is at least one other serious issue at play here, which has to my knowledge, not been documented anywhere and it affects every scanner tested so far.
If a control channel becomes 'active' (for want of a better term) with a voice call and it sends the scanner to a voice channel that is close in frequency to another very strong control channel, or even another voice channel, the scanners IF filtering is not sufficient to prevent overload from the adjacent strong signal and this will prevent the scanner decoding the voice channel.
I have seen this occur on local non-simulcast trunking networks.
The problem occurs when voice channels fall within 50Khz of another very strong control or voice channel. In practice, you get 100% decode rate on the control channel, but the voice channel breaks up or doesn't decode at all. This occurs on every scanner I have tried including the PSR600 and the UBC996xt. It is a flaw in the scanners IF filters that allows strong signals to break through and interfere with nearby channels.
One way you can see if this is occurring is to open the squelch and tune +-50Khz from a very strong local control channel. Do you hear a strange 'silent' channels just up or down in frequency from the control channel? This is the control channel signal breaking through the cheap IF filters and blocking that/those frequencies. If the voice frequencies fall within ~50Khz of the strong signal, it is highly likely that you will not decode the P25, even if not a simulcast channel.
The only way to eliminate this problem is to try and reduce the strength of the strong interfering signal and this is where paperclips or yagi's can be of benefit
The fact is that the IF filtering in a $500 scanner is just not up to scratch on narrowband trunking networks, let alone ultra-narrowband systems with 6.25Khz steps..
Sorry..
