Thanks so much for your help walking through this. The idea that I can’t create a FL for my area
Is really frustrating. Scanning isn’t really supppsed to be that difficult - just turn the scanner on & listen.
But I guess the scanner wins b/c I don’t have the time to sit in front of my laptop & program the scanner
Like it needs to be.
I use to be able to listen to my FL just fine for my area - now it’s just a hassle.
I will probably be getting rid of this scanner if it’s this difficult to program in order to
Listen to a few of my favorite channels.
Thanks again & I wish I had the knowledge you do so I could listen to my scanner the way
I want.
You can listen to 'just your Favorites list', as long as the list is created correctly. Did you verify that your
correct location was set, as I mentioned
earlier? Location does work, provided that you have the correct location set in the scanner
and the systems/sites/talkgroups you load have their correct locations entered. While for your Favorites lists, and for the one Troy created for you,
do have location, one common error (this does
not apply in your case) is to add sites, systems, and talkgroups manually, without also entering their location data. This results in the scanner treating them as location 0 degrees for both latitude & longitude. That 'location' is in the Atlantic Ocean, off the coast of northwest Africa. Read this for more information on how location works:
How it Works: Location, Location, Location
For my purposes, I create Favorites lists with systems, sites, etc, that I
know I can hear, and leave location off. The only time I use location is if I'm traveling to an area not familiar to me, in which case using location with the scanner connected to a GPS device loads the systems that should be receivable.
For Houston PD, you can listen to only your area's dispatch, if you use the correct talkgroup(s) for that area. As I've also noted earlier, a "mutual aid" talkgroup is not it. Looking at the system in the database, if you wanted Houston Central Dispatch, you should use TGID 30040, Central Dispatch, not 30184 Central Dispatch Mutual Aid (General Government Services Layer) which is what is in your "Walton" list. Harris County S.O. should work with the dispatch TGIDs in your HCSO list, IF the location is set correctly. That's why Troy & I have encouraged you to turn off location for now. Use that
only if your lists have location data in them for both the talkgroups as well as the tower sites,
and if you have the location set correctly in the scanner. Since Troy's suggested list worked, but when you used it to re-make your two lists, they did not work, that hints that location is incorrect.
