As we who? I ran Motos with drop in's for years. Had several with remote mikes that NEVER left the charger. Maybe not supposed to, but my batwing dealer never said never.
And if you can't charge the 436 and listen at the same time- don't want one.
Are you wanting to cycle your batteries in and out of the scanner and use the scanner as your battery charger?
Personally, I have always used a good external battery charger that charges EACH battery to the extend that it needs it and it was often said that they were faster and safer (if a battery cell should short out it will take your $40 charger with it not your $600 radio).
However, I have also read that the x36HP radios will shut off the charge cycle if they start to overheat, so Uniden may have addressed this problem (when one or more of the batteries "short out"). In addition, I have read in several places that the faster you charge your batteries the shorter their life span will be. Therefore, Uniden's "trickle" charge approach may actually help your batteries last longer, although some external charges apparently also have a "trickle" charge option.
I keep several changes of batteries for my portable scanners that are segregated with respect to how many full charge cycles they have had (it is important to run the battery down to a certain point before recharging if you want to get the longest life out of the battery).
Therefore, I think you will need to cycle your batteries and keep track of how discharged they are before recharging them regardless if you can charge them while listening to the radio or not. Of course if you use your radio every day a predictable amount you may know when the batteries need to be recharged.
I also keep regular non-rechargeable batteries around since I have lived in tornado alley and in blizzard country and major events can last several days.
