BCD436HP - Programming hierarchy
douglasphansen
DUH
Just had the "duh" moment.
When I was appending things to the favorites list, I was appending each "system" to the list as a new favorite. Not adding each system to the existing favorites. Basically I was favoriting everything.
For 2018, I wish for a brain.
Y'all rock.
Thank you guys - Helped me work out the blips on the radar.
Best,
Doug
drdispatch
If 1000 hertz, think what 1 gig must feel like
Fightin' River, Michigan
I'm in the same situation. Just got my BCD436HP after using the 396XT. The manual has the steps to switch them off and on but the problem I find is there is no easy way to visibly see which departments are enabled or disabled
It would be nice if there was a line of departments under the line of available favorites and Systems that showed which departments where enabled and disabled.
If you press the "Function" key, the top line will become the System line, and the second line will become the Department line. It will show the system being scanned at the moment you press the "Function" key. It reverts back after a few seconds.
