BCD436HP/BCD536HP: BCD436HP - The Sensitivity "test" (it had to come out eventually..)
Boatanchor
There is also something going on with the scan speed.
I've read reports about slow scan speed, but am only now starting to realize just how slow it really is.
I've just disabled all trunking systems in my 436HP and am now scanning about 30 conventional analogue and digital channels. It takes 6 seconds to scan the 30 conventional channels and turning the squelch up to 15 and taking the antenna off makes no difference!
That's only about 5 channels per second.
If I only scan my aircraft favorites (7 channels), it takes about 1.5 seconds to scan only those few channels. And this is without any band switching going on.
Disregard this comment ^^^^^^ -- Was operator error on my part --
Somehow, system hold had been enabled for one of the conventional systems in my favorites list.
I can't really think of a reason to have additional system hold on trunking systems, let alone on conventional ones.
Anyway, you live & learn.
B
jonwienke
More Info Coming Soon!
VA
Maybe, this is one on the reasons why people are noting that analogue reception is improved by rolling back to previous firmware versions. It's not that the radio is becoming more sensitive with previous firmware, it's just that the squelch is opening more reliably on weaker signals and users are hearing more.
Now that actually makes sense, as firmware changes would not affect the performance of the RF amplifier transistors.
Boatanchor
During the testing process (and in use), it became evident that the BCD436HP 'S' meter is calibrated differently to the BCD396XT or the PSR500 etc.
It takes quite a strong signal to even bring 1 bar up on the 436HP S meter while at the same signal generator level on the 396XT, 2 or 3 bars are displayed.
AA6IO
Cerritos, CA (LA County)
It takes quite a strong signal to even bring 1 bar up on the 436HP S meter while at the same signal generator level on the 396XT, 2 or 3 bars are displayed.[/QUOTE]
I also notice this just from my listening experience. Signals on the 436HP that sound just as strong as on my 396XT, PRO-106, or new WS-1080 don't hit the same bar level, usually at least 1-2 bars less in general. Many signals will bump my PRO-106 or WS-1080 right up there, whereas a 4 bar signal on the 436HP is indeed a 4 bar signal (whatever that means). But then again, S-meters on many ham rigs vary quite a bit.
Steve AA6IO
kc5igh
Velarde, New Mexico
To the best of my knowledge, none of these radios' signal-strength meters are calibrated against each other.
Please pardon me if I'm stating the obvious, but for me the sensitivity issue has always been a two-step dance.
Step one is whether or not the radio even receives a signal at its lowest reasonable squelch setting (the one that just barely quiets the squelch background).
The second step is how clearly the radio demodulates the signal is once it's broken the squelch, and I know that's somewhat subjective, given different users' listening preferences (bass, treble, acceptable level of signal over background noise, etc.) and the condition of their own ears (my 65-year-old ears ain't what they used to be).
I'm really interested in this possibility that internal noise may be interfering with the 436's ability to detect VHF and UHF signals. I've been using my 436 as the portable radio it was intended to be with a variety of portable antennas (Uniden factory antenna, Diamond SRH-519, and Comet HT-55's), but I will soon be checking to see how well it works with an external antenna.
I'm going to be a little depressed and despondent if the 436 works as well with the same external antennas as does my 396XT because it probably means the 436 has an internal noise/shielding problem that a firmware update is unlikely to solve.
It may be my imagination, but it seems that many of the 436 owners on this forum who are happy with their 436's have them connected to external antennas (base and/or mobile).
Unfortunately, if I'd wanted a BCD536HP, I would have bought one in the first place.
Thanks for listening.
-Johnnie
jonwienke
VA
Not me. I run my 436HP with a Diamond RH77CA whip antenna on a daily basis, and get great reception with it. I use it to listen to CSX and DC Metrorail during my daily commute. I do have base and mobile antennas, but they get less use than the whip.
sibbley
Nazareth, Pennsylvania
-Johnnie
Not your imagination. I've felt the same way, that's why I started a few months ago testing with ducks, mobiles, and RS antenna I bought for the attic. I've used in total 23 duck antennas with the same results (bad) including Ht-55 and SRH 519. Best of the best in my tests is the RH77 and RH 789 (789 is the best fully extended).
That said, using mobile and the attic antenna (antennacraft ST2) have had the absolute best results.
Disappointing for me, because like you said above, I would have bought the 536 if I wanted a base or mobile unit.
Mike_G_D
Vista, CA
zz0468's analysis and comments are dead on and absolutely should be kept in mind throughout all future tests and result analysis!
Considering the limitations of the testing method and very small sample size, the relative types of tests (using the same method to test two different items and comparing them - in this case the 436 vs. the 396) have the most "relevance", pun not actually intended. So the difference between the 396 and the 436 results probably have more merit than the absolute value of the single unit measurement of the sensitivity. For example, if we see that the 396 is relatively "flat" across the measured bandwidth versus the comparatively "uneven" spread for the same bandwidth with the same setup then that is a data point of interest.
Having said that, though, zz0468 is quite right in pointing out how little a few dB of difference makes to a moderate signal level as heard by a human given all other variables are equal.
Sensitivity, as I've mentioned many times before, is a largely overrated (and vastly oversimplified) consumer scanner specification. And it is VERY misunderstood by the average hobbyist. What you really want is usable sensitivity given more real world conditions. So how "sensitive" is the radio in the presence of local noise both internally and externally generated?
Tests like P1dB and Third Order Intercept require more than just a service monitor to perform but are very important and telling tests!
The easiest test to perform is for basic SINAD sensitivity. But that doesn't tell you everything nor does it tell you all that much outside of making sure the radio meets its published spec. within measurement error and acceptable product manufacturing variation.
Considering the poor phase noise of the synthesizers in a typical consumer scanner as well as other internally generated broadband noise sources (poor shielding allowing nearly all noise generators to be problematic such as all digital electronics including clock generators, all gates, microprocessor, timers, etc.) having the squelch behave oddly on different bands is not all that "strange" of a result. Consider that a typical FM squelch uses a noise gate method whereby a high frequency filter is used to "isolate" the FM noise present on a signal. The more noise the more it mutes depending on your setting of the threshold ("squelch" setting). So a signal with "full quieting" means that there is little to no noise coming through that filter and being detected so the signal is "allowed" through easily. A moderate signal with some noise present will also pass assuming the threshold is not set too high. And on down the line until we come to very noisy signals that have more high frequency noise present than the squelch noise detector's threshold is set for and we get muting.
So when you think about that, you can see that, while in a nice clean RF environment, say inside a screenroom, and with a purely resistive or nearly so 50 ohm source driving it with a very clean signal and assuming the local oscillator driving the receiver's mixers is also clean than the squelch action is largely dependent on signal level and nothing else - higher level means less noise and vice-versa.
But then you add noise to the mix both internally and externally and the noise gate squelch will act on what it is designed for - noise, regardless of level.
When strong signals are present within the passband of an RF amplifier its noise floor will rise - more broadband noise and reduced "sensitivity" (not to mention other non-linear effects). When you are talking about the final RF amp right after the final IF conversion, as zz0468 stated quite well, you have now down converted all of the combined noise sources along with the desired signal signal and the final discriminator and noise gate ("squelch") must act on that amalgam of a signal. If the signal is otherwise a reasonably moderate or even strong signal but is noisy it will still likely get muted by the squelch (assuming the content of the noise is strong within the noise gate's filter output). This is why you can see a strong S meter reading and yet it won't break the squelch.
I'm guessing that the squelch tables in the 436/536 attempt to compensate for variations in internally generated broadband noise on different bands as well as the IF filter bandwidths selected. They are used to attempt to yield a more "smooth" and "linear" squelch action across the entire RF bandwidth and IF filter selection of the scanner. I am guessing that without those tables, you would see a very large variation in how the squelch behaves on different frequencies and using different IF modes. The tables probably adjust the noise gate threshold up or down relative to mode and frequency so that if, for example, a user sets the squelch at position "4" it attempts to compensate for noise floor variations between what is present at 155MHz versus what is present at 40MHz and 860MHz so the user's "4" setting seems relatively the same across all bands and modes. Without the table, that setting might have to change between 2 and 8 or so across the different bands and modes which wouldn't be practical for normal use. Of course it isn't perfect, you only have a limited set of tables and compensation points; so some variation still occurs and those tables really only account for internally generated noise and not outside noise sources of course.
The P25 signals may not use the squelch in the same way as they don't "quiet" the same way an analog FM signal would. They may, in fact, use a completely different squelch action solely dependent on detected signal level or BER (Bit Error Rate) so setting the squelch just right for an analog FM signal at 45MHz might not work well for a P25 signal at 856MHz.
My guess is that the firmware changes that seem to affect sensitivity do so partly by adjusting these squelch table settings. They may also do things like slightly altering certain digital timing settings (including even, maybe adjusting the microprocessor clock or the number of allowed clock cycles needed for various functions) which, in turn, can change the internal noise characteristics thereby changing the noise floor of the radio receiver.
So, as simply put as I can think of, I think the firmware changes likely affect what the user perceives as "sensitivity" through two means - altering the noise floor of the receiver by "adjusting" internal necessary but noisy "noise sources" (either indirectly in order to improve or modify some function or directly in order to reduce RF noise) and by adjusting the squelch threshold tables to compensate for those changes.
That's just for analog FM - there are a slew of other settings likely available which can affect apparent P25 "sensitivity".
-Mike
joeuser
The Wretched
North Central Kansas
-Mike
Very insightful & informative! Thank you!
jonwienke
VA
Is it really necessary to quote 10+ paragraphs for a 1-line response?
kc5igh
Velarde, New Mexico
Well, at least some of us are trying to see a little humor in all this.
Hang in there, everyone!
-Johnnie
joeuser
The Wretched
joeuser
The Wretched
This thread is like fly paper! Anyone else?
OK! Anyway, Boatanchor - will you be testing the 396 (or are you)? Curious to your results, very curious!
Romak3
Banned
IOWA
She waved her hand and said its not worth it the effort. Never mind...
