Flagship... Well this is revealing! Its disappointing... I appreciate you doing these tests, perfect or not - for a layperson such as myself the point is made.
I wouldn't read too much into those results.
First off, I am NOT doubting the accuracy or veracity of Boatanchor's measurements.
What I am commenting on is just how significant the measured difference is. It's clear that the 436 is inferior on the particular test that the OP made. But taking the worst case measurement at 820 MHz (?), it looks like the spread is -115 dbm for the 436, and -118 dbm for the 396.
That's about 0.4 uv vs 0.28, a spread of about 1/10th of a microvolt.
Now, take any receiver and inject a signal down near the threshold, and vary it + or - 1/10th of a microvolt. In a blind test, you probably wouldn't notice a difference. Watching and expecting a change, you will barely perceive it. I stand by my earlier comments that the actual sensitivity in microvolts is not what's causing the perceived poor performance on the 436.
Addressing the out of spec 0.4 uv sensitivity for a moment, there's a couple of things that need to be considered. One is the calibration of the instrumentation. There's a signal generator and a sinadder somewhere in the mix. There are a lot of complex factors that come into play when determining accuracy, and absolute accuracy down to 1/10th of a microvolt resolution is 'iffy' outside of a metrology lab. Differences in input impedance of the receivers will cause errors between the two receivers, and in overall absolute accuracy. I guarantee that the input impedance to these receivers is NOT anywhere close to 50 ohms resistive. It's a complex impedance that will vary with frequency. Differences in the IF filters will affect the accuracy of the SINAD measurement. And so on.
That's NOT to disparage the measurements in any way. I'm just trying to point out some of the measurement uncertainty that will ALWAYS be there. The closer the tolerances you're looking for, the more those minor details will add up.
BTW, 0.4 uv for 12 db sinad for a 12.5 KHz receiver bandwidth translates to a 6.2 db noise figure. If one is familiar with some of my previous technical rantings about scanner sensitivity, I have mentioned repeatedly that the typical scanner noise figure (the measurement that REALLY counts) is around 6 db. So, in other words, this is comparable to everything else out there, within a pretty close margin.
To the OP, Boatanchor... Please don't misread my comments. Your measurements are good, and quite interesting. I've made it a sideline of my career to understand receiver sensitivity measurements and receiver performance, and even when using metrology grade cables, adapters, and instruments, there is always a margin of error, especially when making power measurements. A receiver sensitivity test is a power measurement, in a very real sense.
So, in the end, I'd call the .4 uv on the 436 a wash, if a bit sloppy on Uniden's part. Usually a manufacturer gives a bit of wiggle room on the specs, and may even issue two specs, one as "guaranteed", and one as "typical".
