BCD536HP Not scanning until Dept button pressed
dberhow
I know i must be doing something wrong, but I don't know what.
I have programmed a P25 system using Sentinel, and uploaded it to the scanner. When I power on it appears to be scanning, but there is no signal strength indicated, and it never picks up anything.
If I press the Dept button twice the signal strength then shows up and it scans fine, until powered off.
WTH am I missing?
Thanks/
RF-Burns
Having the issue with Genesee Counties Phase 2 System. Scans no problem then all of a sudden the signal is lost and I have to hit the System Key Twice to get signal back. Any ideas?
dberhow
Solved
Turned down the squelch an it works as expected.
Odd that it would work fine if I would double press the Dept key with the squelch up.
