poboyradio
I know that Tulsa County uses OKWIn P25 Phase 1 Simulcast. Can I use the BCD996P2 or do I have to spend the money for SDS200, which is out of my price range? This is my first post. Thanks in advance.
So what is your question?Can I use the BCD996P2
Look at the map of the simulcast sites in Tulsa County.I don't have the BCD996P2 either. I dont want to spend $350, on the 996 and find out that it won't work. I know that the person providing the Tulsa County Police feed for Broadcastify is using the SDS200. The Simulcast makes it a little unsure, if it will work.
Buy it from amazon.com and if it doesn't out, keep the box and all inside contents and return it within the 30 day window for a full refund. You don't even have to pay the return shipping to them. You print up return label and drop it off at UPS or a Staples store.I don't have the BCD996P2 either. I dont want to spend $350, on the 996 and find out that it won't work. I know that the person providing the Tulsa County Police feed for Broadcastify is using the SDS200. The Simulcast makes it a little unsure, if it will work.
That is great. I appreciate the reply. I was thinking of getting a Terrawave 900 MHz 15dBi Yagi Antenna. I live a couple miles west of the airport on Apache. The 2nd St Downtown and the 31st & Garnett towers look about the same distance. Aiming at either one won't have any towers on a direct line past it. What are you using for an antenna? Thanks...I'm running 2 996P2's with no issues in Tulsa.
Mine are set-up as mobile and use 800Mhz antenna's, For home use I have a scantenna. If you go Yagi you need one for the 800Mhz.
In Broken Arrow, you are far enough east of the main cluster of sites that simulcast is not an issue. That's much the same as my experience with the numerous simulcast systems here in the DFW area. I'm far enough out, they pose no problem. If and when Dallas & Dallas County build out and activate their planned P25 Phase II system, that will likely change, as I would be surrounded by simulcast sites in all directions and varying distances.I'm running 2 996P2's with no issues in Tulsa.
The directional antenna quite often can be a workable option. The downside is that you are mostly limiting yourself to the system your antenna is aimed at. A system that is, instead, in 'back' of you (opposite direction from the way the Yagi is aimed), might come in poorly, or not at all.On the BCD996P2, I was asking if it would work in in Tulsa County which is Simulcast. Some say that Simulcast might get interference from two or more towers close by depending on the area. They also suggest using a Yagi to aim at a specific tower.
That's why I suggested ordering from a dealer with a consumer friendly return policy. That way, if the 996P2 does not work, you could return it with little, or no, cost, then decide if it's worth it to you to move up to either the SDS200
I would just wait on the antenna for now, radio comes with one and after you program it and see how it does you can decide on an antenna.
For when you get the BCD996P2, here is a Tulsa OK FreeSCAN file for programming it.
This zip right here! Thank you Tvengr! I've been sweating it out all night trying to figure out this bcd325p2 for Tulsa not understanding. I grew up on scanners. But back then it was just punch in the frequencies and go. Not so much anymore unfortunately. Now the help is vague and scarce.For when you get the BCD996P2, here is a Tulsa OK FreeSCAN file for programming it. Save the attached zipped file to your computer and extract. Open the extracted file with FreeSCAN. Click on Scanner tab and Upload Programming. Highlight Erase All Systems and Settings and click on Start Upload.
OKWIN Tulsa site is on system quick key 1. Group quick keys as follows:Thank you Tvengr!
1. Tulsa Co Sheriff | |
2. Tulsa Co Courts | |
3. Tulsa Co Jail | |
4. Tulsa Co DPW | |
5. Tulsa Emerg Ops | |
6. Tulsa Police | |
7. Tulsa Fire | |
8. Tulsa Airport | |
9. Tulsa City DPW | |
0. OK HighwayPatrol |
