BCD996P2 reception
rogerd1944
Hi I live in Moosup and have the BCD996P2 scanner.I have troop k simulcast troop D and E but have trouble getting any more then 3 bar signal so I have trouble receiving there broardcast.Any idea what I can do to improve This? I Belive I am using the tower on Econk hill.would a better antenna help with this .?
pro961
for the heck of it put a paperclip in the antenna jack I works for me in Wallingford for Troop I G F
iMONITOR
Silent Key
S.E. Michigan
It's not impossible to monitor simulcast P25 systems on a BCD996P2. I've been doing it successfully on a 14 site simulcast system for year with great results.
@rogerd1944 how many antenna sites are on that system in your area and how far are they from you? What are you using for an antenna and where is it located? Are the signals dropping or severely distorted?
CT
I am in Central CT and monitor State Police with a 996P2, among others. I can receive all of the troops from here.
I would suggest an external antenna to improve reception, due to your location.
The better your antenna can see the transmitting antenna, the better you'll receive the system.
Good luck!
KC1IMD
Connecticut
Does anyone have the locations of the repeaters for the State's CLMRN locations?
rogerd1944
I think 2 towers. I use the antenna that came with it sometimes 3 bars sometimes 5
nhfdcadet
CETsr
New Hartford, Ct
dimab
CT
is there a way to overlay the Troop geographic areas on that map?
n1chu
Farmington, Connecticut
Some houses are wrapped with a metallic foil backing on the insulation. It has a tendency to turn your house into a “Faraday Cage”. This may help reduce splurious rf emissions coming from outside the house interfering with electrical equipment inside the house, but it doesn’t help when there’s a scanner sitting on the desk with the stock antenna it came with. The paper clip suggestion dealt with simulcast issues where a couple of transmitting sites might be strong and mixing with each other. The paper clip would have an antenna toon effect, reducing signal strength, with the hope one site would then win out over the other and give you intelligible audio. But I believe your post related to nothing heard. Glad the mobile antenna worked outside… wondering if it would work inside?
PS. I haven’t seen any mobile directional antennas that need to be “pointed” in the direction of the transmitting site. They are Omni-directional, just stick it up vertically as high as you can get it-it will receive equally well from all directions provided there are no obstacles between the antenna and transmitting sites.
