BCD996P2 Scan Problem
jaruiz02
I have programmed all the channels that I care to listen to into the scanner. However when I press scan, it begins to scan all randam channels including one called "Custom 1", "Public Safety", along with my channels I have inputed.
I only want the scanner to scan my channels. Before I did an update it functioned that way but I am not sure what I did to mess it up.
Any assistance would be greatly appreciated. I used FreeScan to program the channels.
tvengr
Well Known Member
Baltimore County, MD
If your screen says ID Search, press the Function Knob and then press the SCAN/SEARCH button to change to ID Scan.
ka3aaa
middletown, pa.
press the function button, scroll thru all the systems and lockout each system that you dont want to listen to, then press the scan button.
phask
zanesville
The Custom1 is most likely a TG / Freq that YOU entered. Any new entry by default uses Custom 1 as the service type.
