BCD996XT Reverse Burst?
Brian7M3
Wallingford, CT
Can anyone tell me if the BCD996XT responds to PL reverse burst when decoding? I have the GRE PSR 500 and I know this scanner does but was wondering if the 996XT does.
Thanks,
Brian
Boatanchor
Probably not.
The XT series scanners have slow CTCSS decoders that are slow to react even on quiet tail systems.
I have a nearby FM LMR system that cuts the CTCSS tone a couple of hundred mS before the carrier drops. Usually, on a 'real' radio and even GRE scanners, this eliminates the squelch burst as the repeater tail drops, but not on the Uniden scanners.
Avery93
AL
I can confirm that the 996XT (as well as the 346XT and BCT15) does support reverse burst, but not very well. It works about 50% of the time with the 180° phase shift (used by every manufacturer except Motorola), and around 75% percent of the time with the Motorola standard 240° phase shift.
When it does work, Unidens keep the audio muted for too long (almost half a second I think), which means you may miss the first part of transmissions immediately after a reverse burst is detected. This is fairly common when someone replies on a repeater with a short hang time (around one second or so).
Boatanchor
Lets hope Uniden fixes their CTCSS decoder problems in the next models (if they are ever released).
Brian7M3
Wallingford, CT
Thanks for the feedback guys. I currently have the PSR500 but I am looking for a base scanner. The GRE responds to some systems with reverse bursts but others it actually produces a larger squelch crash with the PL decode on than with it off. I guess it is not hearing the reverse phase and keeping the squelch open waiting for it for a few extra milliseconds.
I am considering the BCD996XT because the VHF and UHF receive seems pretty bad on the GRE. I guess a good recieve is better than proper tone decode. :)
I have noticed that the GRE has lots of settings to fine tune the PL/DPL decode that I have listed at the end of this message. I don't have the BCD996XT yet, but I haven't found any settings like these mentioned for it. I checked the FreeSCAN software and don't see any way to adjust the decode settings on the 996 through that either.
CTCSS/DCS/NAC ACSQ SrcInt Wait for HD5 sig in auto CSQ
srch
500 10-2000, x1 ms Search Interval Search Delay Length of time to wait for a CTCSS/DCS/NAC signal in auto carrier squelch
search
CTCSS/DCS/NAC ACSQ PolInt Interval to poll for CSQ value 100 10-1000, x1 ms Query Interval Query Interval The interval of time to check for a CTCSS/DCS/NAC signal
CTCSS/DCS/NAC HD5 Fade CSQ fade delay 2000 10-10000, x1 ms Fade Timeout Fade Delay Length of time to wait after losing a CTCSS/DCS/NAC signal. Max value changed
from 2500 to 10000 in firmware 1.4
CTCSS/DCS/NAC HD2 Qualify CSQ end detect threshold 75 1-1000, x1 ms End detect qualify Qualify Time
(Analog)
Length of time to check to detect an end of signal turn off code command​
CTCSS/DCS/NAC HD2 Holdoff CSQ post-end wait time 500 10-1000, x1 ms Delay after end Mute Time Length of time to mute a signal after an end of signal turn off code command
