Clats97
Ottawa
Hello, I recently started a BCFY feed, and I use BUTT to stream it. I noticed in the settings under primary audio device it has a dropdown list to select the audio source, then to the right of that it says "left" and "right". Left has 1 selected and right has 2 selected. The channel mode is set to mono as sdrtrunk is also on mono.
Should I leave the settings the same or do I select 1 for left and 1 for right?
Thanks.
