Bct15 Bandscope
moses_108
Turtle Lake, WI
What is the purpose of utilizing the BCT15 Bandscope utility, and how can we benefit from feature. In other words I know nothing about it. Please explain. thanks.
UPMan
In Memoriam
Arlington, TX
This feature allows you to :
  • Get a "picture" of spectrum activity across the selected range
  • Identify intermittently active frequencies.
  • See the relative signal strength of signals in the range
And some more stuff that I'm sure others will chip in with.
EDIT: More from the Proscan page:
Band Scope is a tool that can check the antenna performance, coax quality, coverage areas, interference, etc. Bands of frequencies to sweep are configured in the scanner "Search for..." --> "Edit Custom". Simply hit the start button and let the scanner go into action. The window slider control puts a range of frequencies in view. Some of the bands are interesting. Sweep the bands from 25 MHz to 1300 MHz.
moses_108
Turtle Lake, WI
That would be a very useful utility. I have a few different antenna assemblies, so if I get locked on to a few good frequencies and test with some good bandscope monitoring software I should be able to test the quality of each individual antenna setup right. And eventually install the antenna with the best performance working with the frequencies that I normally listen to.
ProScan
Software Provider
Ontario, Calif.
Here is a screen shot of what Band Scope looks like in ProScan.
ProScan Screen Shots
I noticed an error on the ProScan page with the supported scanners. ProScan Band Scope also works with the BCT15 when Uniden updated the firmware.
If you haven't updated the scanner's firmware, Band Scope may not work. Here is the Uniden BCT15 Firmware page.
