BCT15: BCT15 FW Update
AngWay
Curious
Buchanan, Va
I also just got a BCT15 today and it's becomming confusing...the scanner is detected in proscan but i'm trying to do a firmware update on it with BC_VUP3 and when i try to update it says the scanner could not be detected. any help? Thanks
ProScan
Software Provider
Ontario, Calif.
The front panel connection is needed for firmware updates.
Whiskey3JMC
Google-Foo Ninja 4 Hire
Simulcastylvania, TE
Did you select BCT15? There is a BCT15 and a BCT15X.
Good point. I don't have a BCT15 or 15X to test nor the updater app in front of me but would step 1 (to remove the batteries) even come up as an option if the BCT15 or another model without batteries were selected?
tvengr
Well Known Member
Baltimore County, MD
ProScan also has a good point. You must use the front Hirose connector for firmware updates. The rear DB9 connector will work for programming, but not for firmware updates.
merlin
DN32su
Farting around with my BCt-15X, I did the update but the only version was 1.07.00
