Beaufort County fire tones
peten1vak
Greenville
I've documented all the county fire dispatched homes in Pitt county. The only way I knew to do it was Record when the tone went off and then use a program that's free on the Internet and decode the frequency (in HZ). And then put these in my indication G4 pager and they all worked great. I do listen to Washington, and Beaufort County but I don't have any tones for any of the stations there. But this is one way you can do it.
blueline_308
Eastern, NC
What is the name of the program that you use program that's free on the Internet ?
Thanks, Jim
peten1vak
Greenville
The app that I used is called tone finder. I believe people use this for tuning instruments. It was free. Basically you open the app and you put your phone near the speaker of your scanner or the tone you have recorded and it will tell you what the frequency is in hertz. It works great
blueline_308
Eastern, NC
thanks
CommRX
Eastern NC
Multi agency call with Chocowinity involved toned out as 378.0 | 569.0. Most likely 378.6 | 569.1. I'll update if I seen any changes on future calls. Reception is terrible this morning across the range.
CommRX
Eastern NC
Also, this ancient program works very well in addition to the built in features on most newer Uniden radios.1753109094517.png
yardbird
Concord, NC
Why not locate an older Uniden BCD396XT, Uniden BC345XT or the Uniden BCD436HP
They are great for decoding fire and ems tones
The BC345XT was the scanner I used to decode the Gaston County Fire Tones. I was using it to decode EMS but they have since took down their old system.
I have all three and they work super great.
David
