Beck Cabs
ocscan
Ottawa, On
Beck Taxi on is on 159.1350mhz with the Cabs transitting thier car number via DTMF when the PTT is pressed. No CTCSS is used on this freq.
ocscan
Ottawa, On
Am monitoring all cab licensed frequencies now with my Opto456...once i have a bunch of info I will submit....
Currently going over old notebooks and logs and submitting alot of boring/interesting/odd info
mikewazowski
Forums Manager
Oot and Aboot
Have you recently monitored CTV on 152.090Mhz? I had heard they had moved to Fleetcom.
ocscan
Ottawa, On
That logging was today...someone keyed the/a mike...Station ID was logged via Morse Code
mikewazowski
Forums Manager
Oot and Aboot
Interesting. All operations have moved over to an iDEN system. Not sure who would be left on that old frequency.
DaveH
Ottawa, Ont.
You didn't by chance submit a TG to system 1fdd (026-1)? That one hasn't
been used for years...
Dave
DaveH
Ottawa, Ont.
Also, I'm trying to understand how the fleetmap for Moto System 4218
(C&W #1) can be updated when there has been no activity on it in going
on 2 years. See note that I put in the database from Dec. 2005. It
looks like a system waiting to be shut down. Also note system 473b
in Kingston seems to be gone off the air; there was hardly any activity
on it in the last few years.
Dave
RainbowSix
Aaroport Limo-461.8625-167.9
A1 Cab-164.4600-114.8
Arrow Taxi-168.9300, 167.3700, 167.4300
Air Flight Limo-150.3950-131.5
Airline Limo-451.2750-136.5, 458.9375-156.7
ABC Taxi-163.8750, 150.8150
Aeroport Taxi-172.3650, 452.1125-103.5
Airlift Limo-460.1000-151.4, 460.1125-88.5
Areofleet Taxi-167.4000, 163.6500-114
Beck Taxi-159.1350
City Taxi-150.8450, 150.8900
Halton Taxi-166.3800-
Kingsborough Taxi-173.0850, 170.7600
Scarborough City Cab-408.1125
Golden Taxi-412.3125-114.8
jellotor
Hamilton, ON
Heh heh, yes. The last, um, ALL of the CTV shooters I've come across are using iDEN.
Busted.
slipslope
152.090Mhz . . . lol . . . I'm a little rusty on my morse code. can't this bleeping, bleeding edge high tech bcd996T decode morse code?!
ocscan
Ottawa, On
Don't think anyone is actuallly "using this frequency..." but the repeater is still on the air...
exkalibur
York, Ontario
Check 150.280 for Beck as well. They have 5 frequencies. This one is used downtown.
CTV is totally off of analog these days, they're all on the Harmony 900MHz IDEN system.
DaveH
Ottawa, Ont.
Or did the repeater just ID by itself, or get tripped by a bit of interference...?
The repeater may well be still operational but no longer used.The
IC licenses appear to be still active. Sometimes it takes a long time for
these to expire, and the equipment to get taken down or re-assigned.
Perhaps it is a space-holding tactic (spectrum and otherwise).
Under these conditions, I'm not sure how useful posting this frequency
would be if there's no activity, it just ups people's expectations of hearing
something.
Dave
ocscan
Ottawa, On
DaveH said:
Or did the repeater just ID by itself, or get tripped by a bit of interference...?Dave
Not sure logged a TX with CTCSS tone, then recorded a station ID.
Dave
Perhaps it is a space-holding tactic (spectrum and otherwise).Dave
Not sure but its there...
Dave
something.Dave
How many TG's listed are programmed on the Trunked Systems listed on this website, confirmed by member....then never used by the agencies...
Should conventional "capabilites" meet a different test?
I will say that the original post did generate alot of current info...t
jellotor
Hamilton, ON
I'll say this, I only submit frequencies/talkgroups that I've heard audio on. Otherwise I can't confirm who the user is. Most of the other regular contributors to the database follow the same conventions.
Your post did generate 'current info' but the fact is a kind soul went through the database some months ago (specifically the Fleetcom stuff) and pruned out the talkgroups that were no longer active, such as the CTV stuff. Granted, CTV isn't going to show up anywhere in the database but addind a VHF repeater licensed to them that isn't in use is just going to confuse people.
We have a few VHF licenses here that are also not in use...maybe I should submit them? Or our STL microwave frequencies?
exkalibur
York, Ontario
Is it maybe possible that some in house stuff uses it?
I don't remember the frequency off the top of my head, but I remember hearing CTV Agincourt security on a VHF channel a few months back.
jellotor
Hamilton, ON
That's a possibility, assuming of course that Agincourt (or the Temple) has its own security staff and they're not contracting it out. I can't see much of a reason for a VHF frequency to be used within the TV operations...all IFBs and wireless mics will be up in the 500 MHz range (and pretty low power anyway) and anything else wireless (the STLs or even a WiFi network) would be up in the microwave bands.
I suspect, without any more information than what's available here, that the repeater on that frequency is still active because the engineers who would disable it have better things to do than take it down. It's not 'cost effective' to pay an engineer to deal with that when a) the repeater really isn't in use and b) it's only confusing or even of interest to some scannerheads.
...in the meantime, the gradual rollout of HDTV continues and anyone who knows broadcast engineering knows how much brainpower and man hours has been going into that.
mikewazowski
Forums Manager
Oot and Aboot
Keep in mind that we're talking about a simplex channel not a repeater. What was probably heard was a base station located somewhere in Toronto.
Security is up in the 154's somewhere. I forget the actual frequency.
All other operations are on iDEN including the helicopter.
