Best radio for Air band?
G7RUX
So simply to ask, what filter bandwidth is used on AM in case of IC-208 please?
If it is too narrow, then lack of 8.33k could be an issue for scanning the band.
If it is a bit wider then it would work with let say 10k steps, isn't it?
-m
I believe the AM path uses the FM narrow and wide filters, so 6k/12k (at -6 dB). I am not clear whether one can select wide/narrow when in AM mode on this radio.
Edit: Having read more of the manual and specs it seems clear that AM and AM-narrow are both available, so 12k for standard AM and 6k for narrow AM (these are at -6 dB on the filter...the -60 dB filter width for each is 30 kHz and 20 kHz respectively.
Ahh, many thanks. I should read manual own self first for next time...:)
So, it seems that it should not be big issue with lack of 8.33k for scanning.
G7RUX
Indeed, although it depends whereabouts you are.
Could you recommend where I should (at best) insert the VHF FM band stop filter, please?
Current config is: Antenna Diamond D777 at 11m on the roof > Airband elliptic BPF at its feed point > Switchable pre-amp then after at the same place > LMR400 coax 15m long down to shack > FT-350E (to be added IC-E208/IC-208H thru splitter)...
Thanks for hints
Ubbe
Stockholm, Sweden
It will depend of the quality of the pre-amp and the signal level of interfering signals. A good pre-amp can handle most situation and can be installed directly to the antenna to compensate for any losses in filters.
If you have very strong FM broadcast signals then the pre-amp might need protection by the band stop filter. If it's easy to reach the antenna then the best would be to do a test. If a constant transmission like ATIS can be used then that would be preferred to check when that signal have the best quality when filters and pre-amps are installed at different positions.
/Ubbe
Many thanks!
I am already filtering the Airband 118-138MHz elliptic BPF at the antenna feed point in front of pre-amp. This pre-amp can be bypassed if not needed by remote control. So, I am thinking if it is better to put in front of pre-amp (between BPF and pre-amp) or put it down ito shack directly in front of radio. (to avoid any breakthrough due to imperfection of the feeder shielding...
As you said, the best will be to make some tests on the air using 90km away ATIS... (but just in theory ...?)
-m
G7RUX
Many thanks!
-m
Personally, I would put one in front of the BPF, possibly switch-bypassable with the preamp, and another at the input to the receiver. This way you prevent the amp being clobbered by large OOB signals and the one at the receiver ensures there isn't an issue with cable leakage (although that's unlikely.)
Ubbe
Stockholm, Sweden
If that are some kind of generic relay or diode switch then maybe you can have the filter, any filter, in front of the pre-amp and bypass the filter and compare reception quality to check if the pre-amp can handle your local RF situation without filters. It's usually a scanner that have bad specifications. Do you have the name of that pre-amp?
/Ubbe
/Ubbe
I would like to test two LNAs.
I have prepared these
Procom PRO-LNAHP-4-3-2
and lowcost TQP3M9037…
w8prr
WEST LIBERTY
So, it looks like BCT15X is out.
I found some reviews (incl. my local club friend’s experiences) which says this radio has pretty bad selectivity and low sensitivity…
So my search continues.
-m
Have to disagree.
I run 4 BCT15X's all on air band and find them to be great.
Using a collinear for 150Mhz with 1/2 inch hard line and split with a Channel Master tv splitter and works fine.
There are more expensive splitters that are likely better but works great for me
INDY72
Indianapolis, IN
I run an Uniden BCD396XT with an Nagoya 771, it's actually pretty amazing on rail and both VHF, and UHF air.
Ubbe
Stockholm, Sweden
I believe the Procom to be the one used at VHF sites in the 80's. At Procoms webpage it says:
Gain 18dB
P1 +17dB
OP3 +31dB
Noise 1,5dB
Compared to a modern low cost PGA103+ (semiconductor costs $5)
Gain 22dB
P1 +22dB
OP3 +45dB
Noise 0,6dB
As the gain are 4dB higher the P1 and OP3 are also 4dB too high compared to a 18dB gain but the PGA103+ still has half the internal noise and considerable better OP3.
The TQP3M9037 only covers 700MHz to 6GHz so are unsuitable.
/Ubbe
Gain 18dB
P1 +17dB
OP3 +31dB
Noise 1,5dB
Gain 22dB
P1 +22dB
OP3 +45dB
Noise 0,6dB
/Ubbe
Thanks for wake up me mate. I have also one assembled board with PGA103+ unused. So, it looks like it's time now to put it on board... :)
So what did you get????
Unfortunately, neither of the two options for buying the IC-E208/IC-208H came to fruition. One seller stopped communicating when he found out I was from Europe, and the other sold it to someone else (or so he said) ...
So, I'm looking for another one and still using an old FTM-350 as main unit.
-m
Colin9690
Delaware County
Lewis Center, OH
Easy answer! The “Motorola” of aviation handhelds, the Icom IC-A25.
Sure it’s expensive, because your life might depend on this. Reception on TX and RX is spectacular even with the stock antenna. Good to know if things go south. Even while transmitting an unusually large percentage of the battery cycle, the battery life is really really good. I’m pretty chilly WX too.
I use it while not in or around the aircraft, pick up the ATIS and of course as a back up radio to another backup radio. And of course, while at home or even at the airport watching other aircraft, I’ll use it as a scanner. Because it blows every other receiver out of the water on VHF-A.
I do not need more handhelds.
I am looking for as best as possible desktop/mobile solution which will extend my home setup.
Anyway thanks for your effort.
-m
jaymatt1978
Cape May,NJ
-m
Seriously I would then either get a BCD996T or BCT15X. They are basically the best base/m obile scanners for air
