prcguy
Yes, most duplexers will pass two channels 50KHz apart with no problem. The receive multicoupler would basically be a two way divider and low noise high IP1/IP3 preamp with low gain. Here is a pic of the TX combiner I bough cheap used that would combine two transmitters 50KHz apart into a single duplexer. I still think a dual slot Mototrbo/DRM solution is the best.
Edit: That is not my specific TX combiner as its missing the 3dB hybrid, mine looks identical but with the hybrid mounted against the front panel.
In this situation I would avoid separate TX and Rx antennas entirely.
Use the two channels 50KHz apart.
I had the opportunity to look at a 4 channel NXDN trunk system. It uses a single antenna, with a 6 cavity ResLoc. All 4 transmitters we’re combined to a single feedline, to the low pass side of the duplexer, all the receivers were combined with a receive multicoupler fed from the High pass side of the duplexer.
Crecend amplifiers, Sinclair transmit combiner, Sinclair dual circulators , Sinclair receive multicoupler, Sinclair Duplexer.
