BK KNG P800 squelch problem
cpetraglia
Fairfax, VA
My portable is probably 4 years old. Been perfect until very recently. Now when it breaks squelch with a P25 TG it has a loud thump type noise. Everything else is still working fine. I have tried reloading the code plug with no difference.
Anyone have any ideas. Thanks
IAmSixNine
Dallas, TX
Perhaps try reloading the firmware.
Its possible it has developed a hardware issue. I would hope not after 4 years. My KNG2 P800 is approaching 4 years and last year it was sent off due to failing RF deck. It was at the end of the 3 year warranty. They replaced some parts and gave me a 1 year warranty on the radio.
cpetraglia
Fairfax, VA
No I don't. It's just a loud thump right at the beginning of a transmission. My other P800 does not do it at all, nor does my M800. It must be a hardware issue.
gtaman
TACSAT
GALAXY 19 91.0° W
The speakers trend to go bad pretty easily in these. Attach a speaker mic. If the issue goes away it may be related to the main speaker. If not then I would send it off to FL to be looked at.
IAmSixNine
Dallas, TX
Wait, so your hearing the thump through a small amp attached to your speaker mic?
If you dont hear the thump from the radios speaker or the speaker mic its possible your amplifying the audio amp kicking in when the raido is about to pass audio.
Similar to how Unication Amplified speaker/charger used to do something similar. In fact it was heard most often when it was tied to an online feed.
cpetraglia
Fairfax, VA
I have two other BK radios that all go through a mixer and a small amp. Only this one radio in particular makes the noise. My other two are silent.
IAmSixNine
Dallas, TX
Ok thats better.
My best guess is hardware failure. I like the radios but there are still some bugs in software and not sure how well they will hold up long term.
I have had my APX 8 years and no internal issues.
2 years into my KNG2 and it went back for factory work. That was a year ago.
cpetraglia
Fairfax, VA
Yea, but the thing is, I don't move them around at all. I am very gentle with them. By using an external amp, I keep the radio volume low. I had worried a little about all this when I put out the bucks for them. Nothing lasts like stuff used to.
MTS2000des
5B2_BEE00 Czar
Doesn't bode well for a "desk queen" radio that has an electrical failure in that short of a time. I wonder if the factory will support your product and repair it for low/no-cost? They are a small company compared to the other guys, so they may be more apt to keep an end user happy especially when the product is faulty and not run over by a fire engine.
cpetraglia
Fairfax, VA
I took the chance and ordered a new aftermarket speaker/mic. Reconnected it all the way it was and the thump noise is gone. So it must have been a failed circuit board in the speaker/mic. Problem solved. Thank god it wasn't the radio.
