BKR 9000 Thorough Review
gtaman
TACSAT
GALAXY 19 91.0° W
Just updated and still having it, but maybe just to a lesser degree, especially on Phase 1 CPQSK. Phase 2 still sounds garbled on a system that lots of different devices have trouble with in my area. There are other types of radios that handle that system flawlessly but this BKR9000 just doesn't sound good on it. Everything sounds under water with occasional clicks and pops. I have only had a few minutes to test that specific system but there's two dwellings in that county currently.
Here's video of the Phase 1 system on the new firmware. Yes it is a very weak signal coming from pretty far away. But none of my other radios have that skipping that this does.
That stutter at 21 seconds is the issue I see. It’s almost like the radio is not properly decoding CQPSK. Even setting CQPSK only does not fix it.
policefreak
Berlin, NJ
Here is the troublesome 700mhz Phase 2 trunking system. Again other devices have trouble with this system and some do not. I live a mile away from this county and the nearest transmitter is about 6 miles away and likely facing my direction. As you can see, most of the audio is copyable, but there's some skipping and overall it just sounds...ugly.
policefreak
Berlin, NJ
Here's that same Phase 2 system on an old KNG P-800. Loud and clearer. Yes, I know the date and time are wrong. Yes, I know it's old and I beat the devil out of the thing, but sounds pretty good and works great.
gtaman
TACSAT
GALAXY 19 91.0° W
It for sure sounds like a modulation issue. My radio does the same on weak systems as well as the clipping audio.
policefreak
Berlin, NJ
I agree. Some other more distant and weaker P25 phase 2 in the same 700mhz band sound beautiful on the BKR9000 in their sweet spots. Others sound just ugly.
PacScan
Los Angeles
BK replaced my speaker front under warranty for that peeling issue.
My new one is starting but I think I may put a small slit in the corner to make it flush so it doesn’t peel.
Do you have simulcast issues? Where the audio will essentially clip randomly when rxing.
Just sent mine in for the warranty repair. How long did it take for you to get it back?
