Programming the BCD996T for Dummies
Maalox, thank you very much! I did it..........duh With your help
I could understand your instructions just fine. I stand to be corrected, but I can't find those instructions anywhere in the manual.
Okay, so that looks after entering a conventional channel. Baby steps I guess! Now on to the harder stuff!
enter freq on the keypad press e it will say quicksave enter no the dot key then youll see which system you want to enter it press e twice then it will give you the menu options then set it with the name then set audio type to digital or anaolog then press e again tyhen press the hold key freq should be entered into your system
