I don't know if this question has already been asked or not but please notify me if it has and link me to the original.
To simplify: Why does VHF use 5 watts while UHF uses 4?
Full Explanation:
I want to know; why are VHF radios set at 5 watts while UHF is set at 4? Since UHF has a shorter wavelength, shouldn't it have a harder time with reach, unlike VHF? So why does VHF get a +3 watt boost but UHF only gets +2? (Differentiating from the standard 2 watts every VHF/UHF/800? handheld has.)
It just doesn't really make much sense to me other than UHF is more standard in denser populated areas, whereas VHF is more standard in open terrain. But one thing that catches me is, why VHF needs a full 5 watts even though it doesn't struggle much in those wider areas but UHF which is also sometimes used in those same areas only gets a -1 watt difference?
Maybe I'm getting a bit too over my head about this, I'm surely not mad or frustrated about it either, it just makes me kind of curious as to why. Also, I get there's not much of a difference in wattage.
Full Explanation:
