Firemantincan
- Joined
- Feb 21, 2017
- Messages
- 66
Have you entered a custom band plan? The Calvert system was re-banded in 2011, and the standard Motorola band plan used your scanner (and the 325P2) may not work "out of the box" without making some adjustments. The Uniden HP-1/2, and the 436/536 have the updated band plan in their database, thus are not affected. I verified this today with UT2. Running the standard Motorola band plan, UT2 was calculating a few invalid system frequencies - which can cause parts of (and entire) conversations to be lost. Once I entered the band plan for re-banded Motorola systems, it was able to calculate the proper system frequencies. My "control" scanner - an HP-2 - had no problem following conversations because it was using the correct band plan from its database.
That was going to be my next question. What band plan are you guys using? I went ahead and updated to version 1.07.9. I figured out that the band plan was an issue. I changed it to a custom band plan with a lower freq of 851.9125 and an upper freq of 853.3500 and a spacing of 5khz. that has helped quite a bit. However, there is still an issue. My 785D is pretty good at tracking the system.
Today I'm showing the CC as 852.1375. The CC signal is good. I have a full 5 bar signal and can currently copy a patch to SMC on 8TAC93 100%.
I have the 785 on in the background and can hear units talking on the TRS but, its not coming over the 996. the 996 is showing that it is trying to do something and recognizes that a TG is in use but doesn't track it. I can see it registering that a TG is being used but does not move to the frequency and TG being used.
So just to recap:
I can confirm that the signal is not an issue.
The scanner is scanning and I can see that the CC is 852.1375
When a user is talking on a TG I can see the scanner recognizing that specific TG is in use, but the scanner does not follow it to whatever frequency it is on. And just to clarify that the scanner is in scan when I see the activity.
The 785 has no problem tracking.
