Can Motorola XTS 3000 800mhz be programmed to transmit and receive on LWIN...
There are several good deals online for these Motorola XTS 3000s. My question is, could these radios be programmed to transmit and receive traffic on LWIN P25 frequencies that are on the 700mhz band? Many of our members are without radios and I am hoping to find a temporary affordable solution to this problem.
RayAir
I do not believe the XTS 3000 will do 700MHz.
You could use the XTS 5000. This is what I'm using.
I wouldn't recommend buying your radios on eBay unless you find a reputable radio dealer and still there are many requirements to program these radios properly. You'll also need to make sure the radio has the proper options installed.
WX4JCW
Stow, Ohio
I would also contact the LWIN System Admin to make sure they have the software and equipment to program them as he will probably need to approve them/program them for use
you wouldneed a xts5000 or anthing from 2500, or any of the APX radios
KC5AJP
Lake Charles, La.
Which District are you a Captain of? I work closely with La Radio and program my department's radios. I may be able to help you get some radios. I know there are several grants which we applied for and obtained radios for every member of Calcasieu Parish Fire Departments. I think Allen Parish also just did the same. Let me know how many radios you are needing and what your budget is and I will get with LRC and see if there is something we can do such as grants or incentives. Please send me a private message with your contact information.
