Can someone explain?
pmsar35
San Francisco Bay Area
Hello,
Looks like your Base Frequency should be 141.015, this is separate from the control channel frequency of 142.095...
HUNTD
Thanks Paul, but I must be missing something else too.
What does CT: 105.88 mean? I never put that in anywhere? I thought it might be a CTCSS Tone, but it doesn't appear in my list of available tones.
I can tune to 142.8300 and hear the digital signal, 2-3 bars on the FM signal strenghth meter, so I'm pretty sure i'm close enough to pick up the trunk.
Do I need to indicate to the scanner that the channels 401 and 402 are the controll frequencies? Or is that what the Trunk option means, therefore i shouldn't have all four frequencies with the trunk option on.
Any other ideas?
Thanks,
Dave
HUNTD
Admin, I have options for AM, FM, WFM, NFM and AUTO but no option for MOT unless I'm missing something or changing this in. I have tried all these modes and still don't seem to hear anything but the digital static.
I do appreciate your help and patience.
I will be reading the manual again tonight, I must be missing somthing.
:D
Cheers,
Dave
HUNTD
Woo Hoo!
I got it, thanks so much for the help guys!
I really wish I could tell you what my problem was, but I can't.... I removed all references to the trunk in the bank and then programmed the scanner blank. I then reentered all the info again, wrote the bank back to the scanner and presto... I am now scanning the Trunk!
:oops: Thanks :oops: again :oops: for :oops: everyones :oops: help :oops:
Dave
seamusg
Grand Blanc, MI
I can see one problem with your setup - Donot set a trunked freq as PRI. The radio will keep trying that freq.
HUNTD
Hi seamusg,
That makes sense, and i will change it, but i'm not sure that was my problem as I still have it set. The channel that is set as PRI is the alternate control frequency and I do not hear the digital static on it when there is no transmittion.
I have looked over the screen shot above and what I have setup now three times.... I still can't see anything different... Chalk one up for learning! :wink:
Cheers, Dave
