Good morning.
My beloved SDS100 started acting up this morning, and I can't figure out what might be wrong. The issues I describe below seem to have started this morning when I turned off all my favorites lists, except for two digital trunked systems (one of which I reprogrammed last night).
Trunk-tracking issues:
-Audio is now intermittent on my most closely monitored TRS (strong, nearby P25 simulcast system - no problems at all until now)
-"DATA" and "LINK" flash intermittently as it searches for ID's, but no signal-strength bars are visible
-"P25" message lights up and stays on when it occasionally receives and transmits audio
-Talkgroup channels flicker on and off the rest of the time, indicating traffic, but no audio heard
-Unication G5 working perfectly at the same time (so it's not the TRS system)
-Can't seem to hear anything on the other P25 TRS I reprogrammed (New Mexico DTRS), even though it worked well last night
Conventional monitoring issues:
-Receiving static and hanging up on many, but not all, conventional channels, even with the antenna removed (seems to be hanging up on analog channels without squelch tones, but it's hard to confirm because it's so difficult to monitor any conventional channels at the moment)
-Adjusting the squelch level doesn't seem to help, causing me to suspect the static is internal
Contributing factors?:
-I reprogrammed one (New Mexico DTRS) of the two trunked radio systems (mentioned above) yesterday that I wanted to monitor again this morning, along with my P25 simulcast system (the reprogrammed system worked well last night)
-Updated Sentinel to get latest information on the New Mexico DTRS before reprogramming the SDS100 (It's a long shot, but I can't help but wonder if that didn't somehow have an impact on everything else in the SDS100)
-Recharged the radio overnight (It's probably my imagination, but it seemed to take a little longer than usual to fully charge)
Unsuccessful remedies/ideas so far:
-Reloaded last night's programming (Didn't solve the problem, although it seemed to be working fine last night on the updated DTRS I mentioned above)
-Considering "Restore Options" to either "Clear User Data" or "Reset User Settings" and reloading the Sentinel programming, but fearful of doing so without some advice
-Wondering if this might somehow be an SD Card issue, but I haven't tried messing with it yet
Miscellaneous:
-Latest version of the SDS100 firmware installed
-Latest version of Sentinel software installed (Version 2.02, revision 01)
-Latest version of Sentinel's RadioReference database installed
Miscellaneous:
