Can't seem to hear P25 in Summit County.
sbhnutts570
Akron, Ohio
Do I just type in the 857.2625 and 857.6625 or all the the frequencies listed under Marcs -IP. I can't find where it says Site 2-002.
wmlovell
Aurora, OH
I receive it with just 857.2625 & 857.6625 programmed in. After the migration, there will probably be the other two.
Swipesy
Northern Ohio
Type in the Blue and red frequencies as your system frequencies and enter Talkgroups - Bingo
sbhnutts570
Akron, Ohio
Where do I find the talkgroups at? I have the blue and red typed in, but I hear nothing. I have a TRX-1 and am downloading from that library where it says Marcs 2-002 Summit County and all it gives me is the wildcard channel.
KWs
Kent , Ohio
Talkgroup located under Summit County 77 in the database under MARCS IP
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
If you don't add the talkgroups you will have to at least add a Group Wildcard for the system. If you want to hear everything, even if you don't have all talkgroups programmed in, then add the Group Wildcard anyway.
budevans
Cleveland, Ohio
Is the database current for this group?..Just downloaded latest data .....very sporadic traffic
A couple of questions. First, which database are you referring to? Second, which Summit P25 are you referring to? The prior Summit P25 system is in the process of migrating to the MARCS-IP Summit County P25 System.
To see the current status of the move, go to the RR Database Ohio-Summit County and scroll down the page till you see the Trunk systems. Select MARCS-IP. In the MARCS-IP P25 system you can sort the Sites by clicking on the County column top of the listing. It take a second to sort. You can then scroll down to see the new Summit sites listings and their control channels. Next scroll down the page past the Site listing and you will see the MARCS-IP County Talk Group listings. Scroll down to Summit County to see the TG's for each Summit Site.
KWs
Kent , Ohio
If you are downloading the ,latest database on Sentinal , these new TGs won’t be showing up til Uniden releases the next update, usually on Monday’s.
sbhnutts570
Akron, Ohio
Thanks for your help but I still don't see any talkgroups under Marcs Ip 2-002 Summit County 77. I am giving it up for today,been working on this all day.
Wilhelm1234
Akron
Sounds like I'm on the wrong system..guess I'll have to wait a week or so for online software to catch up.. thanks
budevans
Cleveland, Ohio
Wilhelm1234
Akron
Thanks.....I just heard dispatch tell someone they were on the "old channel"..so that's definitely the problem!
Wilhelm1234
Akron
When I try to import through freescan it shows 2 Marc's systems but does not allow me to look at contents (individual departments)..any ideas?
sbhnutts570
Akron, Ohio
Well after a long day of manually installing channels on trx-1 because their library isn't up to date yet I finally got this scanner to work. Heard all of Summit County last night at 8pm. Got up this morning and nothing,dead as a door nail. I don't know whats going on now.
KWs
Kent , Ohio
Are you on MARCS or the former Summit P25 system, which may have been taken down today. You need to be monitoring MARCS.
k8zgw
Macedonia Ohio
I have just returned home, a hour and a half ago and have heard NOTHING other then the
Euclid Police, which I am hearing from the Cleveland system.Usually I hear Hudson and Aurora
constantly and haven't heard a peep in 90 minutes.
Something must have changed.
Do I need to add the "old"P25 system channels to the IP system as well as associate the TG's to the "new" system ??
I am really just getting re- acquainted with WIN500 and am a little confused as to how to move stuff around.
It took me 20 minutes to figure out how to add a conventional channel yesterday.
Don
