Radio hobbies can be very expensive. Nice job on the RF bonding. Most people don’t go that far.the money I have spent is unbelievable... and you really don't want to be boarded.. but ok, I bought RF bonding for my pick up so I got a few 12 foot rolls of 1 1/4" braided strap... I bought 50 terminal ends... I bought the crimpers for 00 thru 8 AWG terminals and a roll of 4 awg ground straps.... I bought a trans hump cb mount $50 ( it didn't fit) I bought a multi angle floor mount piece $50 but that wouldn't fit either... VERY hard to get the radio in the truck... I bought a junk yard pull out tray for my pick up that I mounted my CB to and is working nicely.... I bought several fittings and cables.... the LMR400 was $109 the RG8 was $89 after taxes... the Tram3500 was under a 100 bucks when I got it....and can be bought for 50 now... I bought 3 top fence rails $30 each and two 1 1/4 EMT 10 footers plus stainless steel bolts and washes.... almost $300... I bought a lightning arrestor 90 bucks.... I found out I have to cut the LMR400 so it will come down the side of my mast STRAIGHT into a large waterproof box ( the plastic hinged box was $50) I was going to go past the box and up from under to make a drip loop.. but I was schooled that lightning will not do curves or bends thanks Bill..... so I spent $300 at DX engineering on LMR400 ends and a crimper and a stripper then another set of jaws for the crimper so I can do my RG8 then RG8 ends and a RG8 stripper.... then I guess i'm going to have to solder the center pin... so I bought solder and a soldering iron..... I also bought a relay for my mobile so I can go from the battery to the CB with 10AWG and when I shut off the key in the truck the CB will shut off.... I am trying to get a Mic holder for the truck.. got a magnet one but it doesn't fit my mic so I got another that sticks to the dash but it sticks out too far... there is no place to mount my base station on my work bench so I got a computer monitor arm bracket so I can mount it to the side of the bench and swing it to were I can see it and use it and still have my whole work bench... I bought 4 Stainless steel house to mast clamps ... I bought a couple of SWR meters... didn't seem to work ( real junk so I got the Rig Expert... ( WOW NICE UNIT) .. I've bought ground rods and grounding cable grounding clamps... I have a guy coming in to dig an 8 foot hole for my ground rod... I live on a rocky area... spent years learning you just can't dig on my property... all rocks the size of a watermelon you can't get them out with a post hole digger.... dummy loads.. all the bolts and star washers for doing the RF bonding on the truck... I have a 100 bucks into bolts washers drill bits ext... clear paint ....blue paint U bolts... I could honestly go on all day.. and it's more than a grand... I have a addiction / passion for CB handhelds... I now have over 30 of them and have been buying tools and testing gear for them so when I get my base station up I will be doing range testing and power testing on them and see what I can do... I thought it would be nice to take the dog for a walk and go out 1 mile and try to talk to the base.. then 2 miles and then 3 and then 4..... I will set up a video recorder on my base station.... going to be fun if I ever get the base up and running.... but if I had known three months ago when I retired.. I wouldn't have done it! ..for all I know my Cobra may not work! ... on the truck.... I did RF Bonding 6 places on bed to the frame... 4 places cab to frame... RF Bonding from CAB TO BED ...fenders doors ...hood... then I put 10 ground straps on it.... it all takes time and MONEY .. I could keep going but as I said I thought I would bore you ( sorry)
