CB Gods hate me .... Ebay LMR 400 is no good?
niceguy71
Massachusetts
It looks perfect..... Everytime I screw a connector on to my Rig Expert it bottoms out on the plastic top boby of the Rix Expert. So the top of the coax connector is loose and I can turn the Rig Expert in circles as the threads are as tight as I can get them but the coax cable behind the connector is loose .... Best way to describe it.... But the Rig Expert works really good as soon as I push the pin into the Rig Expert and the threads touch it gives me a reading..... The LMR 400 has Big heavy duty ends so it's exacerbates the problem a little requiring me to play with it more
G7RUX
This sounds like it could well be an issue; pop the casing and see what’s going on in there as the 259 shouldn’t foul the casing…it sounds like there may be either damage or just a loose connector that needs sorting. The AA-170 (and probably the AA-54 too) does not have an internal cable as the SO239 pin connects directly to the board via a soldered jumper…
rescue161
KE4FHH
Hubert, NC
Out of curiosity, what type of connector does the Rig Expert have? I hope it isn't an N-type.
rescue161
KE4FHH
Hubert, NC
Nothing is wrong with N-type. I prefer them to the UHF PL259. I absolutely loathe PL259 and SO239 connectors.
The problem lies with folks not realizing that the connector is an N female and cram a PL259 in and it splays out the center conductor of the poor N female, forever ruining her.
G7RUX
Oh of course, I had forgotten about that.
Still, from the OPs‘s description of the connector situation I suspect the issue is the broken socket or it’s connection to the internal board.
RFI-EMI-GUY
That should not be happening at all. Are you sure you have the correct connectors on everything being mated?
G7RUX
So I’m being completely clear here, there is no coax behind the connector so if it is turning then something has come adrift.
niceguy71
Massachusetts
I think it's ok... it's just the SO 239 0n the top of the Rig Expert is a little short.... or the connectors I have seem to be deeper on the screw threads.... but I'll take a look
G7RUX
If the connector is turning then something is broken, I do not believe there is a coax jumper behind the connector but it should be soldered directly to the board.
G7RUX
Having looked inside an actual unit of the AA-54 *there is no coax jumper.*
If the connector is rotating then the connection to the board is broken.
niceguy71
Massachusetts
ok.... the RG8 goes onto the RigExpert and never hits the plastic top of the RigExpert it screws on and stops like a normal fitting....... the RG8 was the only one giving me a good SWR.....
.I put a 90 degree elbow connector on the RigExpert as tight as I could.....and tightened the connector in my vise... I then spun the RigExpert in circles... as seen in three pictures..... I then put the LMR400 and again could spin the RigExpert in circles... it does make a connection but it hits the RigExpert and bottoms out so I can't screw it on anymore and when this happens the saw teeth of the connector don't engage I can spin the RigExpert in circles.... but it does seem to give me an SWR reading... I took a picture of the RG8 and LMR 400 I also have as requested some pictures of the RigExpert..... hopefully someone may see something???? now the plastic cover at the top of the RigExpert.... when I had the top of the RigExpert off, I can push the plastic in a little but I didn't want to break it.... so even though the LMR400 is touching the threads and the pin is inside the fingers of the RigExpert do you think the SWR is off???..... thanks again for all the help... I honestly don't think anything is wrong... the RigExpert works... the antenna seems like new and the LMR400 works fine on a dummy load... but something is stopping me from getting a working SWR... and I don't want to put this thing up 32 feet without knowing everything is working correctly.
niceguy71
Massachusetts
no the coax connector is spinning along with the RigExpert not the coax just the connector as if it is not screwed on more than a couple threads
niceguy71
Massachusetts
Does both the LMR and RG cable connectors "spin" the same way?
BB
nope.. see pictures.. the RG8 screws all the way on and stops before it hits the RigExpert... like a normal connection .... the LMR400 hits the top of the RigExpert so the back of the LMR400 never seems to pull tightly to the connector.
niceguy71
Massachusetts
RigExpert is good... it just doesn't let the connector tighten correctly.. but still makes contact and so far has always done a nice job for me ( I had it 2 weeks) ..my Tram 3500 cable and my RG8 both thread on normally and both give me a nice SWR
