CB repeaters?
kc2asb
NYC Area
Don't forget that what you're not telling me something that I don't know. I have been interested in Radio Communications even before I earned my Technician License or applied for my GMRS License. I must admit that I hardy get on the Amateur Radio Band anymore, but I throw my call out on GMRS, which is kind of crazy since GMRS isn't a Hobby as the Amateur Radio Service can be used as a hobby.
When I replied, my thought was that this was most likely something you did know, but perhaps others reading the thread might not. No offense intended.
prcguy
Nice radio. I have one from the original batch when they came out around 2012 or so. However, like a lot of people, my second VFO died years ago. It is no longer capable of cross band repeat, or dual VFO’s. Now i have VFO B shut off and set it to display voltage instead. Still in use in the garage, and can’t really complain as it’s held up for over a decade, other than the dead second VFO.
I had two TYT TH-9800s and two Yaesu FT-8900s and was never happy with the TYTs. The TYTs made an annoying popping sound when the squelch breaks and they never made anything close to rates transmit power. The Yaesu‘s were great and the only drawback was the limited frequency range compared to the TYTs. I ended up giving the TYTs away to new hams as a gift for passing their tech licenses.
Coffeemug
Warminster BUCKS Co. PA
While that’s true, many feel that navigating the FCC’s horribly broken website to apply for a license IS the test for GMRS. ;)
Yep, you're so right, navigating through the FCC site is the test. Of course, there are many individuals that will purchase GMRS radio and yet, they'll neglect to apply for a License or Permission Slip. I know because I monitor a Local GMRS repeater all the time.
WB5ITT
Beaumont, TX
My gripe (dead serious) is with interference on AM-19, The Travelers Channel, and I don’t care too much about the others.
AM-6, The Super Bowl, confines it antics to itself. That’s commendable.
118-possibilities to screw around and have fun (AM & SSB) if we leave out AM-9 & AM-19.
In time — (weird world oncoming re tech and the complete abandonment of our failed physics) — maybe other AM & SSB channels will gain use-adherents with a desired general topic.
I can’t say whether a repeater would be a good idea. But today I think it goes against WHY we most of us may prefer HF Radio over other types.
Seven League Boots.
There are only 40 possibilities. RF is RF regardless of the mode. If you have an AM or FM signal on say Channel 39, good luck on running sideband because the channel's already occupied.
WB5ITT
Beaumont, TX
Back in the early GMRS days, GMRS was known as CB class A and FRS was Class B CB. Class D CB was the 11M 26-27 MHz 23 channels which is 40 channels today.
Class A and B were both on UHF... but restrictions on usage were different between the two. They were both combined into GMRS...
FRS was never under the CB rules. No license required and power output is limited. It came a long long after GMRS came into being
kc2asb
NYC Area
True, but in my experience operating SSB, I have found that it's still possible to have a QSO even while another station is operating AM on the same channel. It does depend, of course, on how strong the AM signal is and how distant/strong the SSB station you are communicating with happens to be. SSB is effective at punching through interference.
merlin
DN32su
I just don't think 11 meter CB repeater is the way to go. Now a cross band remote radio, that has worked in the SoCal area.
A UHF link to a mountain top setup, now you got 3 counties coverage.
slowmover
Fort Worth
You’ve read of these mythical beasts, the AM/FM/SSB mobile transceiver . . just haven’t operated one.
kc2asb
NYC Area
The mountain top setup would be the way to go. It's doubtful that repeaters will ever become common on 11m. They can certainly work on a small scale with the availability of rigs capable of FM and tone squelch, but solo AM/SSB operation will continue to dominate the band.
nokones
Sun City West, AZ
3 Counties coverage, are you referring to Old Saddleback (Santiago)?
merlin
DN32su
Don't recall the site name, If I dig, I can come up with coordinates.
A buddy named "Bob" had a 2 meter repeater there. Eyeshot of San Bernardino, Riverside, LA. Overlooked all of east LA.
So, What Bob did was install a translator, UHF in, any mode. Output mode you selected with touch tone (6 I think)
The 11 meter part was from a Pathcom. Filtered output driving a 100 watt+ PA. That went to a "droopy drawers" antenna about 40 foot up.
Frequency span went from 26.400 to well above 27.470. Worked exceptionally well after the band go quiet. even from So Bay.
Coffeemug
I didn't take offense. Besides, I have to be honest, maybe I do sound like a moron in certain aspects whether it's GMRS or other Radio Services. I just don't want to sound unintelligent, and I certainly don't want to sound as if I'm putting myself down.
