CCRs
alcahuete
Southern California
Honestly, on those analog frequencies I cannot tell a difference in reception quality from the SDS100, probably due to the strong signal.
You would certainly notice the difference if there was another strong signal nearby. The 'fengs and other CCRs are very easily overloaded.
Washington State
Wow, I don't know how long << THIS UV5R8W BUNDLE >> will last on Amazon, but I thought it prudent to post it here in case anyone wanted an awesome deal. It comes with everything pictured here EXCEPT the cell phone, for only $15.49. Which could make a nice Christmas present for someone. Now whether you trust a Chinese APP on your phone or not is up to you.
rf_patriot200
Freeport, Illinois
:poop:
Washington State
UV-17R for only $18.39, if you want one, act fast! << AMAZON LINK >>
Sure, it probably spits out harmonics like a firehose spits out water, but if you only want to LISTEN to analog frequencies, how can you go wrong?
Washington State
No, the USB cable is just for charging the battery if you are away from the drop-in charger that comes with it. If you want to program it via computer you will need << THIS CABLE >> for an additional 10 bux.
alcahuete
Southern California
Is that a 2 LED flashlight now on the bottom? Wow! That's definitely the sign of a great radio. :D :D
AK9R
Central Indiana
Gimmicks, aka "features", sell. Technical quality is not important.
It's like automobiles made in the U.S. in the 1950s. You want chrome plating and fins? Yeah, we got that! You want passenger safety or fuel-efficient engines? Well, um, look at our chrome plating and fins!
EAFrizzle
Bond. Ward Bond
SE de DFW
My Baofengs receive the civil air band just fine.
Lots of people don't care one bit about listening to aircraft.
Reading is next to useless without proper research and demographic information.
Washington State
So many suggestions for radios that do not receive the aviation band. Reading is fundamental.
There are also newbies that are not always aware of the step rate of 12.5 in that band, so when the radio locks onto a frequency, it's not center, so they think it receives like garbage. Either know thy frequency and input it, or scan starting at the right place with the proper step rate.
Just for the record, the 5RM goes into AM mode on the aircraft frequencies and does a fair job of it.
