CDM ghost invalid fields??
K2NEC
5F6
I have a CDM1550LS+ (403-470) that I converted to (403-480) and when I go to write to the radio it shows that there are invalid fields. When I check the invalid fields there are none! Anyone have this issue before or know a work around? My CDM does it no problem but this one is just picky! And I wanted to save the codeplug and try to open it again to see if that did the trick (it won't let me because of these 'invalid fields') but I just spent an hour programming all the frequencies and I would rather not destroy my progress.
K2NEC
5F6
Now in the invalid fields menu it shows "rdkListInfo_4632_9773" and "Not shown in any window"
When I click on it, it shows "This field can not be found"
So it's trying to find something that it can't find?
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
What was the last thing you changed? Often it is MDC fields, scan lists, LTR lists, etc. Time to explore every field looking for the red box. TT
K2NEC
5F6
That's the thing I checked EVERYTHING. Nothing was red. I don't know where the problem happened but I redid the whole codeplug and it didn't have the same error so it must have just been a bug or something.
