CE150 programming disk help needed
sloop
Lewisville, NC
I have a VX-264 radio and a CE-150 programming program. I am unable to get the computer to communicate with the radio. The program keeps saying com port error. When I go to alignment it brings up the com port assignment for me to select comport (there is not a com port showing) but will not let me enter anything. What am I doing wrong? Could the cable be bad? How would I check it? Both cable and program are Vertex Standard, not some after market.
cmdrwill
So Cali
I do not have that problem with my CE150. And I use the older Vertex serial cable.
There is a rather unusual procedure when 'downloading' the radio, having to turn on the radio from a cold start before the s/w 'reads' the radio. Turning on the radio is a part of the signaling between s/w and radio. Kinda old school.
Makes us wonder who wrote this crap they call programming software...........
MBill
Yeh. I wish Vertex would standardize their portables. The old VX-410/417 portables needed to
be switch on first before reading. The later VX-350/354's you turned on after hitting the read
button. Now the newer VX-261/264 portables are back to turning on the radio first. Vertex does
recommend using the FIF12A USB cable rather than serial cable for the later radios and future ones.
Did you check the Vertex menu under "File" and the "Config" choice to see if the correct com port is
selected. Usually its Com 1 for serial cables; you may have choice.
sloop
Lewisville, NC
Yep...checked align but no com port shows and the program will not let me select one. I have tried plug in the cable before and after running import nd same with the radio turned on then off....still 'cannot find radio'
cmdrwill
So Cali
What programming cable do you have? Maybe missing the driver for the cable?
Also what OS, XP, Win 10?
sloop
Lewisville, NC
I had assumed that the driver was part of the CE-150 program. If it is not then that is the problem. The cable is the right cable (can't remember the number). I guess that I will erase the program and re-install it. I will also look for a driver program for the cable. I have never 'tried' to program anything this difficult before. Thanks for all the help.
cmjonesinc
Are you using a USB or serial cable? and what version of windows
