CH-721 Firmware
arbitergvadam
San antonio
Hello,
I have a Harris CH721 Head unit that is showing "SER download please wait" I am assuming this head unit needs to be reflashed with the CH721 Mainapp firmware.
I have had a very difficult time looking for this firmware and I wanted to see if someone can point me in the direction of finding the latest version.
I have been sitting on this for a few weeks now trying to find something somewhere out there.
Any help would be greatly appreciated.
Thanks!
prcguy
The head has been put into an upgrade mode and needs to be reset. Someone has messed with the ABC buttons during power up placing it in upgrade mode. I forget how to get out of it but I thought a power cycle would fix that.
arbitergvadam
San antonio
SOLVED!
the Ch-721 head has had a new firmware flashed to it. If you run into this issue an new firmware is needed.
baloobear40
SOLVED!
Did you have to do anything to it to get it to take the firmware flash? I have a control head that says "download please wait"... I know it needs an updated mainapp, but I can't get it to initialize to take it.
arbitergvadam
San antonio
The program that loads the firmware isn't used in rpm it is a standalone Command line script that loads in a terminal.
Send me a DM and I can shoot you over what I used to solve it.
merlin
DN32su
Be sure the can cable is disconnected, the head cant be talking to the MRU.
Send a serial command "atz-1" with a terminal, that will put the head into burnapp mode.
Alternate: hold the "C" button and power up the head.
Then run the .bat file that came with your version of firmware.
Latest firmware for CH-721 is R07G17.
merlin
DN32su
I don't know if it will exit until the upgrade is complete and "sucess" shows in the display.
Then connect the brick and power up.
