Changing audio input on DSD+
aps_ak
Anchorage, AK
Having issues piping audio from SDR# to DSD+ on my laptop.
On my desktop, it works fine because DSD recognizes the VB cable as the only audio input source. On laptop, the laptop microphone appears as audio input device 1, so no audio comes through to DSD.
Otherwise, SDR sharp works good, receives audio, VB Cable is installed and selected as output option in SDR#, the audio just isn’t making it to DSD, because DSD is listening to my microphone and not the V cable. V cable appears as input device 2.
I know there is a command line to potentially change it - but where do you enter those commands? There is nowhere in DSD+ that takes those commands. (-i, think?).
I am not using the fastlane DSD, just the public release 101
Any help appreciated.
Reconrider
Inside the Galaxy
Radio Galaxy
Code:
Input/Output options:
  -i<spec>    Input audio device (1-255) and channel (M/L/R) [-i1M]
  -i<[addr:]port> FMP TCP link IPv4 address and port number
I read the DSDPlus.txt file. I'm not sure if the public release has it, but it's worth a try.
cmjonesinc
The 'easiest' thing to do is to set your vb cable as your default device. Go to your audio input device menu in windows and right click and set vb as default. You can also edit your dsd bat file per the directions in the readme file included in the dsd directory.
