Charles County Maryland fire and police go dark.
tvengr
Well Known Member
Baltimore County, MD
The software is a demo version until the registration keys are entered. You should be able to register the software by clicking on the Help tab,
w3rsl
Laplata Md
Hi tvengr!
Thanks for your reply. The brand new $69.95 Butel software does not have the demo version listed. I have the ARC 996T registration codes but they are of no use since they have to be entered in the demo version. I was given a address that was supposed to be where I can get the demo version which is :http:www.butel.nl/download.html. However, it sent me to a Uniden page which listed all the scanners available for purchase with the software!!!! Of course, that is useless for me. Guess I'm stuck because I haven't got a reply from Butel regarding my issue.
tvengr
Well Known Member
Just send an email to Butel. I always receive a quick response. Did you purchase the CD or download version? If you purchased the download or CD from Butel, it may already be registered. Go to the Help tab and click on About. If it says full version, the software is already registered and you are good to go. If you don't see Register under the Help tab, the software is probably already registered. You will need the keys if a Windows update unregisters the software or you install it on another computer. Keep the keys in a safe place in case you need them.
w3rsl
Laplata Md
Hi again tvengr!
I sent an email to Butel yesterday but see nothing in my email yet. I purchased the download version. Last time I clicked on help it sent me to the Uniden scanner page, but this time I'll click on about. I got the keys a few days ago but could not use them cuz no demo was there.
OK, if I see full version in the about section will it then ask me for the keys automatically? And if I don't see Register under the help tab about section the software is probably already registered and will it then ask for the keys?
Man, I sure appreciate you help. I was about to throw in the towel!!!
tvengr
Well Known Member
If you see full version when you go to the Help tab and click on About, the software is registered and there is nothing else to do. There is no need to enter the keys if it is already registered. You may have clicked on Open Software Manual which shows this: ARC996 for BCD996T. My ARC996 software shows full version and there is no provision for entering the keys. You will usually get a notification that you are running a time restricted demo version when you boot the software if it is not registered.
w3rsl
Laplata Md
Well, I see the scanner is scanning but don't hear any action. The simulcast is indicating ID search. I did hear the conventual analog FM frequency of 155.085mHz pop up so that is something! I took a look at the system frequencies and noticed 853.2625 is the control frequency and verified it and the other alternate frequencies are listed in the scanner. However, when I selected the control frequency manually, I did not hear the characteristic loud buzzing that usually accompanies an active control channel. That being the case the scanner doesn't know what to do. But when I entered 853.375 in my conventual FM scanner, heard the buzz which indicates it is active! Therefore, I think RR primary control channel is not correct and should be 853.375. Problem is that the scanner does have 853.375 programmed in yet does not recognize it as a control channel, hence no activity again. Any ideas???
davidhut
Well my 996P2 stopped transmitting Charles about a week or two ago. Calvert and St. Marys are fine. Turned on the old 796D and Charles is coming in fine. Makes no since. Gotta be a 996 problem.
maus92
The OP
Doubtful. Nothing has changed in the SmartNet protocol, but the control channel did roll. 99% chance that you have not programmed all control channels into the radio.
w3rsl
Laplata Md
I've come to the conclusion this is hopeless endeavor. Appreciate all the members that responded with suggestions. I hope I can be of some use helping others that have problems. 73 to all, W3RSL silent key.
maus92
The OP
If you want, you can ship it to me and I'll take a look at it.
w3rsl
Laplata Md
Well, it's of no use to me. Send your address to my email: pcj3bw@yahoo.com. Will have to UPS it to you. If you find a solution let me know so I can apply it to my other rig and to my two friends that are suffering with the same problem. Thanks!
tvengr
Well Known Member
If ARC996 is working, give this file a try before you ship the scanner. Save the attached zipped file to your computer and extract. Open the extracted file with ARC996. Go to the BCD996T tab and click on Send Data. I am also including a PDF file which will answer all of your questions about using quick keys. Charles Co MD is on system quick key 1. All of the groups also have quick keys. I also have a FreeSCAN file.
  • Charles Co MD M96.zip
  • Uniden Scanner Quick Key Instructions DMA.pdf
w3rsl
Laplata Md
OK tvengr. Yep, the scanner is operational and picks up 155.065 which is the FM dispatch channel. Will give it one more shot. In the meantime, I found the original box for the rig! Thinking I would be shipping it to you.
Going to see download your file now.
w3rsl
Laplata Md
17040 CCFD 10A1
1520 CCFD MOSCAD
1584 CCFD 10A12
17056 CCFD 10A2
17072 CCFD 10A3
17120 CCFD 10A6
17152 CCFD 10E1
17088 CCFD 10A4
17104 CCFD 10A5
17136 CCFD C7 Trng
17168 CCFD 10E3
17184 CCFD C10 MA3
17200 CCFD C11 MA4
17632 CCFD 10B12
17232 CCFD 10A7
1648 CCFD 10B12
848 CCFD MA Calv
880 CCFD MA 880
17216 CCFD EMS Sec
1616 CCFD 10A13
17648 CCFD 10D16
17248 CCFD 10A8
17280 CCFD 10B3
17568 CCFD 10A12
17440 CCFD 10A14
17600 CCFD 10A13
17296 CCFD 10B4
17312 CCFD 10B5
17328 CCFD 10B6
17344 CCFD 10B7
17360 CCFD 10B8
17376 CCFD 10E4
17392 CCFD 10E6
17408 CCFD 10E7
17424 CCFD 10E9
17264 CCFD 17264
1 ID:1
20 ID:20
w3rsl
Laplata Md
17040 CCFD 10A1
1520 CCFD MOSCAD
1584 CCFD 10A12
17056 CCFD 10A2
17072 CCFD 10A3
17120 CCFD 10A6
17152 CCFD 10E1
17088 CCFD 10A4
17104 CCFD 10A5
17136 CCFD C7 Trng
17168 CCFD 10E3
17184 CCFD C10 MA3
17200 CCFD C11 MA4
17632 CCFD 10B12
17232 CCFD 10A7
1648 CCFD 10B12
848 CCFD MA Calv
880 CCFD MA 880
17216 CCFD EMS Sec
1616 CCFD 10A13
17648 CCFD 10D16
17248 CCFD 10A8
17280 CCFD 10B3
17568 CCFD 10A12
17440 CCFD 10A14
17600 CCFD 10A13
17296 CCFD 10B4
17312 CCFD 10B5
17328 CCFD 10B6
17344 CCFD 10B7
17360 CCFD 10B8
17376 CCFD 10E4
17392 CCFD 10E6
17408 CCFD 10E7
17424 CCFD 10E9
17264 CCFD 17264
1 ID:1
20 ID:20
OK. after educating myself about zip files here is what was sent to scanner. There is another group for sheriff but no need to display that. Still not hearing activity.
w3rsl
Laplata Md
Going to call it a night and let the smoke out of my head. Thanks again for all your work for me! 73 & QRT.
w3rsl
Laplata Md
