Charles County P25
maus92
Eastern Shore
I though I'd establish a new thread for Charles County as their new system is now slated to cutover in January, 2027. Typically this means a FDMA control channel will come online roughly a year prior, which means that should happen soon. AFAIK, they will be reusing existing frequencies - hard to tell because the FCC website is so awful. The revised project cost was $55M at the end of 2024 when a contract modification was granted for different subscribers - probably APX Next data capable radios.
Edit: Charles WILL be getting a few new frequencies licensed previously.
Hbright
Thanks! Just curious if there's a press release or some source you could link?
maus92
Eastern Shore
The go-live date was mentioned in a MD First RCB quarterly meeting recently. The supplemental expenditure for new radios was in a change order document at the end of 2024. The rationale for the subscriber change is that the APX model originally spec'd in 2018 contract with Motorola is going to be EOL shortly.
Hbright
Is the proposed new tower in Waldorf to support the Smartzone system or the new P25 system? I believe the plans for the P25 system include increased coverage across the County (eliminating the need for TGs on the Fairfax Co and Calvert Co systems).
maus92
Eastern Shore
It would not be for the Smartzone system; I think they've maxed out on the number of sites that can be supported. Plus I doubt there are any parts left to build it, lol.
Dispatcher308
Mountains of PA!
Its going to be at the tower behind the old state police barracks/NRP barracks on old Washington Road.
maus92
Eastern Shore
Control channel software like Unitrunker can be used to decode the control channel and determine the alternate control channels. I see one traffic channel in the RRDB listing. If a channel grant ofr BSI was issued, the frequency carrying that grant would also be displayed.
brian86
Maryland
Any idea when they will decide on the talk groups listing?
It is in the very beginning stages, it may be several months before they list all the assigned Talkgroups. My logs are showing 3 active talkgroups right now. These talkgroups (3027, 3028 & 3029) are probably Motorola testing.
brian86
Maryland
Here is a Trunking Recorder Link of all radio traffic form the new Charles County P25 Radio System In Development. You can play back audio from the system for the last 60 days. Make sure to Click "All Dates" in the search options to listen to audio.
Charles New P25 - Trunking Recorder
Hbright
Thanks. I was wondering if they’d use seven digit RIDs on the P25 system. Looks like they are.
maus92
Eastern Shore
Seven digital RIDs are the standard for Region 20, which is basically Maryland, DC and Northern VA counties. Note that the same radio may use different RIDs in different personalities just to confuse things, lol.
Hbright
Correct, but only for P25 systems. The current Charles Co Motorola system doesn’t use seven digit RIDs (but, like you said, the same radios have seven digit RIDs on other systems). 236xxxx for Charles Co.
