Charlotte County Public Safety has completed their 800MHz rebanding.
Did a test. They're 15MHz down from the originals ... from 868 to 853. All talkgroups remain the same.
What band plan did you use? Custom one is not working.
Isn't the 15mhz drop only for EDACS?
if you lower all the freqs by 15 mhz then you will hear them. i use a bc396 and have not been able to use control channel only
Looks like Uniden's HomePatrol Sentinel database has not been updated yet. I just tried a full database update, still not picking up Charlotte county. Only getting Sarasota , North Port.
Any other HomePatrol users in SW FL figured out a work around ?
However, I just found a site I think has the new frequencies. It is Charlotte County Public Services Trunking System, Charlotte County, Florida - Scanner Frequencies See what you think. Arthur
Control channels are 15 mHz lower but, Band Plan must be changed to "Custom" and set up as:
853.40000
853.65000
853.85000
853.90000
Band Plan 1
Base Freq Low 851.0250 Base Freq High 854.0000 Spacing 25.00 Khz Offset 440 (+) Polarity
Band Plan 2
Base Freq Low 851.0125 Base Freq High 868.9875 Spacing 25.00 Khz Offset 0 (+) Polarity
