Charlotte County P25 (00A.92912)
tvengr
Well Known Member
Baltimore County, MD
Charlotte County TRS database discrepancy:
155160fDIT TAC 1IT-TAC-1Public Works
1552610DIT TAC 1IT-TAC-2Public Works
1553611DIT TAC 1IT-TAC-3Public Works
1554612DIT TAC 1IT-TAC-4Public Works
RRdB reference link: Charlotte County Trunking System, Various, Florida
Hi all,
Does anyone have more TG information on the Charlotte County system? dB hasn't been updated since July of this year. I know there is an LE feed on Broadcastify that has a few monitored talkgroups that are not on the dB.. (such as PGPD dispatch ch 2). And from my understanding, Charlotte Co. doesn't want to give up a list of talkgroups via FOIA.
Thank you!
(Also, is this actually a Harris system? I see that all of their deputies carry Motorolas..)
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
everything I have from DSD on Charlotte County. # after 92912.00A = TG ID (decimal) and # after normal = # of hits. I can only copy this system during good band openings.
P25, 92912.00A, 1, 50, Normal, 323, 2022/07/29 0:34, "[CCSO Dispatch 1 ] Dispatch 1 Zones 1 and 2"
P25, 92912.00A, 3, 50, Normal, 420, 2022/07/29 0:34, "[CCSO Dispatch 3 ] Dispatch 3 Zones 3 and 4"
P25, 92912.00A, 10, 50, Normal, 4, 2020/10/14 7:57, "[CCSO Tac 1] Tactical 1"
P25, 92912.00A, 201, 50, Normal, 404, 2022/03/02 7:19, "[CCSO Jail 1] Jail 1"
P25, 92912.00A, 204, 50, Normal, 79, 2022/03/02 7:14, "[CCSO Jail 4] Jail Transport"
P25, 92912.00A, 301, 50, High, 6, 2020/10/14 7:52, "[CCSO Tac 301] 301 Tactical"
P25, 92912.00A, 302, 50, Normal, 30, 2020/11/27 23:54, "[CCSO Tac 302] 302 Tactical"
P25, 92912.00A, 1002, 50, Normal, 68, 2022/03/02 7:19, ""
P25, 92912.00A, 1051, 50, Normal, 22, 2020/11/02 8:00, "[Animal Control] Animal Control"
P25, 92912.00A, 1251, 50, High, 28, 2021/11/04 7:46, ""
P25, 92912.00A, 1301, 50, Normal, 106, 2022/07/28 7:08, "[FireEMS Disp] FireEMS Dispatch "
P25, 92912.00A, 1305, 50, High, 8, 2022/03/02 7:14, "[FireEMS 1305] FireEMS 1305"
P25, 92912.00A, 1307, 50, Normal, 1, 2020/08/20 7:52, ""
P25, 92912.00A, 1315, 50, Normal, 3, 2020/10/14 7:59, ""
P25, 92912.00A, 1346, 50, Normal, 10, 2020/11/02 8:37, "[EMS 1346] EMS 1346"
P25, 92912.00A, 1347, 50, High, 7, 2020/11/02 8:41, "[EMS 1347] EMS 1347"
P25, 92912.00A, 1348, 50, Normal, 10, 2022/03/02 7:15, "[EMS 1348] EMS 1348"
P25, 92912.00A, 1601, 50, High, 12, 2020/11/02 8:39, ""
P25, 92912.00A, 1801, 50, Normal, 63, 2022/03/02 7:20, " (TDMA)"
P25, 92912.00A, 1802, 50, High, 34, 2022/03/02 7:19, " (TDMA)"
P25, 92912.00A, 1803, 50, High, 11, 2022/03/02 7:15, " (TDMA)"
P25, 92912.00A, 1805, 50, High, 52, 2022/03/02 7:19, " (TDMA)"
P25, 92912.00A, 1807, 50, Normal, 0, 2020/08/20 6:26, ""
P25, 92912.00A, 1810, 50, Normal, 16, 2020/11/02 8:26, " (TDMA)"
P25, 92912.00A, 1813, 50, Normal, 8, 2020/10/14 7:45, " (TDMA)"
P25, 92912.00A, 1851, 50, Normal, 114, 2022/03/02 7:19, "[DialaRide] DialaRide"
P25, 92912.00A, 1901, 50, Normal, 4, 2020/08/20 7:47, "[UtilitiesWater] Utilities Water"
P25, 92912.00A, 2601, 50, Normal, 342, 2022/03/02 7:20, "[PG PD Disp] Police Dispatch"
P25, 92912.00A, 2801, 50, Normal, 36, 2022/03/02 7:15, "[PG FD 2801] Fire"
P25, 92912.00A, 2902, 50, High, 4, 2021/01/15 5:00, ""
Based on the 00A sys ID = Harris system.
Network: 92912.00A ; Charlotte County (Project 25)
Bandplan #0: Base=769. Offset=+30 Spacing=6.25 BW=12.5
Bandplan #1: Base=851.00625 Offset=-45 Spacing=6.25 BW=12.5
Bandplan #8: Base=769. Offset=+30 Spacing=6.25 BW=12.5 Slots=2
Bandplan #9: Base=851.00625 Offset=-45 Spacing=6.25 BW=12.5 Slots=2
NOTE: This bandplan is different than what is currently listed for Charlotte County. I will do some research on that.
bravo14
Polk County FL
A few weeks back I was picking up this system in polk county. I'll have to look at my laptop see what it shows.
wanabe
Batdude, Did you ever verify the IDEN Band Plan for Charlotte County? You said there were a couple of different ones. Just trying to program the right base plan for the Harris system into my Harris P7300. TIA
batdude
Moderator
i cannot routinely hear that system... too far away.
bravo14
Polk County FL
A month ago I did get this same info when bands were opened up.
Very interesting information. It looks like the 30X tacs for CCSO are in use a lot more than the standard 2 digit tac channels that are listed. Also what is Dial-A-Ride?
Another note:
2601a29DPG PD DispPolice DispatchLaw Dispatch
2605a2dDPG PDPoliceLaw Tac
2801af1DPGFD DispatchPGFD DispatchFire Dispatch
2805af5DPGFD Tac 1PGFD Tac 1Fire-Tac
Seeing from these TGIDs, it seems that PGPD and PGFD have only 2 talkgroups? They both jump from 01 to 05 for both depts. Assuming ID 2605 is potentially the dispatch 2 for PD like the feeds? I wonder if there are any in between 🤔 or if they jump up to 10, then 15, then 20 🤔
batdude
Moderator
Another note:
Dial a Ride is usually handicapped special public transport buses.
How do I get bandplans for other systems? I am trying to get one for Naples and Hendry county.
bravo14
Polk County FL
Unitrunker is free does edacs and p25 only. Not sure if Unitrunker has a Version 2 download also need a dongle to run unitrunker and 2 dongles for dsdplus. DSDPlus isn't free.
Here is a 1st version 2 for UT. UniTrunker V2
Oh... I don't have a dongle. Trying to find the bandplan for Naples for their system, but I can't find it on the RRdB. Was hoping batdude had something saved.
bravo14
Polk County FL
Okay copy that. If you have a scanner not sure if the bandplan would be set in there when RXing the system.
MTS2000des
5B2_BEE00 Czar
Surely you can ask the System Admins in Charlotte and Collier that gave you a system key to authorize your APX for use on their radio system what their band plans are, yes?
My money says they have their ZW/GW Clone Watch module up and running with triggers set waiting for that bogus affiliation or accidental PTT. Can we say "job security"?
