Cheektowaga fire dispatch
Honch61
Cheektowaga, NY
I am not getting the Cheektowaga fire dispatch channel anymore on my sds200. It is scanning the frequency but not picking it up. I can hear it when using broadcasting, but not on my scanner.
k2hz
Rochester, NY
It could be SDS100/200 problem. See this thread:
mjmurphy61
Buffalo, N.Y.
I'm receiving it just fine. I'm in Cheektowaga.
k2hz
Rochester, NY
I see you posted the same question back in December on the thread I referenced above. The answer is the same, it is an issue with the SDS200. While removing the DPL setting may correct it, like other SDS200 bugs, any fix may depend on the particular environment the scanner is in and results may vary. There are no magic fixes for the many issues that can occur with the SDS scanners.
lkas
Cheektowaga NY
I have no issue with this channel. I have a sds100. I have IFX enabled and the DCS removed. I also added ctcss 123.0 which is the nys tway tone as a lockout to stop the bleed over i get. If you want to send me your email address i can send u my sentinel favorite list for cheek fire and you can import it into your sds200.
