CHP East Sacramento
scannerboy02
From
CHP TWO WAY RADIO SYSTEMS
HOW THE EXTENDERS WORK: The "extender" mobile repeater transmits and receives on the same channel. It works by pulsing the signal it is transmitting, so that it can still listen on its own frequency to check to see if the officer's hand-held radio is transmitting to it. During periods of no activity from the dispatch system, the mobile repeater is idle and simply listens on the 154.905 frequency. When it receives a signal from the hand-held on 154.905, it puts the car's low band radio on the air and relays what it hears (on 154.905) out on whatever 42 MHz CHP channel the main mobile radio is on. When the channel is active with dispatch traffic on the 42 MHz channel, the mobile repeater re-transmits it on 154.905, but interrupts it with short pulses, so that it can listen to see if the hand-held radio wishes to break in. The mobile repeaters had a range of perhaps a mile or less. In order to prevent interference when several CHP patrol cars arrive at an accident scene, the mobile repeaters have a priority scheme, which basically shuts down all mobile repeaters except the last one to arrive at the scene. Hence the "reset" switch on the control head.
W6KRU
Vista, CA
Thanks scannerboy that confirms some ideas I had.
Do the San Diego units that are on the RCS system still utilize extenders?
scannerboy02
CHP Conducting R.A.I.D. in the Newly Established Rancho Cordova Area
In an ongoing effort to significantly reduce the number of traffic accidents and injuries related to driving under the influence (DUI), the California Highway Patrol (CHP) will be conducting a R.A.I.D. (Rapid Apprehension of Impaired Drivers) strike force operation on Friday, January 30th in the Rancho Cordova Area at 7 p.m.
The R.A.I.D. program uses grant-funded overtime to enable the CHP to significantly increase the number of officers on patrol and to deploy them at times and locations in which a high incidence of DUI-related collisions have historically occurred. Led by CHP Valley Division Chief Stan Perez, he and nearly a dozen two-person units will be conducting roving DUI patrols within the Rancho Cordova area and El Dorado Hills
area, as well as a fully-staffed command post at the CHP’s newly established Rancho Cordova Area Office, which became fully functional as the 109th area office on January 30, 2009.
Below are dates and statistics demonstrating the success of past R.A.I.D. deployments:
§ 9/19/08, Stockton, 57 arrests
§ 9/26-27/08, Chico/Oroville, 53 arrests
§ 11/08/08, Woodland Area, 33 arrests
§ 11/15/08, Stockton Area, 53 arrests
§ 12/19/08, South Sacramento Area, 61 arrests
§ 12/20/08, North Sacramento Area, 55 arrests
CHP R.A.I.D. Strike Force in Rancho Cordova/El Dorado Areas Net 32 Arrests
The California Highway Patrol (CHP) conducted a R.A.I.D. (Rapid Apprehension of Impaired Drivers) strike force operation on January 30th in the Rancho Cordova and El Dorado Hills Areas. The R.A.I.D. program uses grant-funded overtime from the Office of Traffic Safety to enable the Department to significantly augment the number of officers on patrol and to deploy them at times and locations in which a high incidence of DUI-related traffic accidents have occurred.
§ Friday’s Rancho Cordova/El Dorado Hills deployments yielded 32 alcohol/drug related arrests and 82 traffic citations.
"I think the message is quite clear," said Chief Perez who oversees the CHP's Valley Division. "Alcohol and drug influenced drivers will be aggressively pursued throughout the Rancho Cordova/El Dorado Hills regions. I'm proud of the hand picked officers of our RAID team who are as passionate as me about doing everything possible to make our streets a bit safer. This is another reason for Valley Division's statewide lead in DUI and drug transport enforcement!"
scannerboy02
Anyone know if the Rancho Cordova office has moved to the blue? I have been getting lots of hits on the blue over the past several weeks but have not been able to monitor long enough to confirm who's using it.
gmclam
Fair Oaks, CA
Sacramento CHP
When I hear traffic on BLUE in the Sacramento area, it is for one of two reasons. 1) There is an incident on Gold, Black or Green. 2) Speed enforcement.
WayneH
Forums Veteran
Super Moderator
Your master site
I doubt you'll ever see BLUE used for local dispatch unless it's a temp thing due to radio issues on the main channel. Blue has always been like a wide-area and/or special event channel.
northzone
Northern California
Not always. Many areas of the state used Blue as the primary dispatch channel for decades. The susanville/quincy area was most likely the last to leave the blue as primary channel. The east sierra (Bishop) also dispatched on the Blue for many years.
As a side note. Quincy use to have a dispatch center during the weekday. At night the sheriff would take their calls and dispatch. The console was "homebuilt' by DGS telecom as where most in the state chp offices. About the only thing you would ever hear at night was 20-10, 20-20, 20-30 will be code 7 at Bucks :) They did not have 24 hour patrol and in fact only got that THIS last month 2009. Just 30 years later from when I monitored them.
I would agree with wayne, at this point in time you will likely never see blue used as a dispatch channel again. They are currently putting 44mhz (yes 44) stations in all over the place. I believe the plan is to give each area a "incident working channel" to free up the main dispatch channel but still have comms with dispatch.
scannerboy02
Ran across this log on CHP CAD from yesterday.
9:09AM SSAC SGT BARKLEY ABLE TO COMMUNICATE ON VLY AMBER 2
9:09AM 112-S4 WILL COMPLETE RADIO SURVEY ON 99 TO COUNTY LINE
9:13AM S4 GOING DOWN TO SR WILL TAKE FLORIN TO 99, WILL CHECK IN ALONG THE WAY
9:13AM SAC CPZ S4 CLR BUT BREAKING I/O
9:13AM S4 ADV SACRAMENTO: CLEAR BUT I/O
9:13AM ADV S4 IF HE LOOSES RADIO CONTACT W/ SAC TO SWITCH TO BLK FREQ
9:16AM SAC COPYING TRAFF -ALL BROKEN W/ STATIC - SOUNDS LIKE A FEMALE TALKING
9:16AM S4 ADV NEG TRAFF FOR SAC - COMING UP ON SR AT DOUGLAS : 10-2 CLR
9:16AM S4 ADV SAC IS 10-2
9:19AM SAC CPZ TRAFF, ALL STATIC
9:19AM S4 ADV NEG TRAFF, SR AT JACKSON ADV ING COPYING SAC 10-2
9:19AM SAC CPZS4 IS 10-2
9:21AM S4 WB AT FLORIN / SAC CPZ 10-2
9:21AM S4 ADV COPYING SAC 10-2
9:26AM S4 -FLORIN AT BRADSHAW, SAC CPZ S4 10-2
9:26AM S4 ADV COPYING SAC 10-2
9:29AM S4 FLORIN AT WATT / SAC CPZ S4 10-2
9:29AM S4 ADV CPZ SAC 10-2
9:33AM S4 FLORIN @ STKN - 10-2
9:33AM PER S4, DISP IS STATIC, 10-1, BREAKING - FLORIN @ STKN
9:35AM S4 - FLORIN ONR TO SB 99 - 10-2 SLIGHTLY LOW VOLUME
9:35AM S4 - DISP 10-2, HAD TO GO OUT 3 TIMES B4 S4 COPIED DISP
9:37AM S4 - SB @ MACK - UNIT AND DISP ARE 10-2
9:39AM S4 - SB 99 AT SHELDON - 10-2
9:39AM S4 COPIES DISP 10-2
9:39AM XRAY VOICE BROKEN AND 10-1 ON ACU1
9:40AM S4 - SB 99 @ EG - 10-2 BOTH UNIT & DISP
9:43AM UNK TRANSMISSION - BROKEN, 10-1, STATIC
9:43AM S4 UNABLE TO COPY DISP DURING THESE BCST TIMES
9:45AM S4 10-1 SB @ GL / BARELY ABLE TO COPY - LOW VOLUME / STATIC
9:49AM S4 ALSO UNABLE TO COPY ANY GGCC BCST
9:51AM CONTACTED AMBER RADIO AT GGCC - SCC DID NOT CAUSE ANY
INTERFERENCE W GGCC
RolnCode3
Sacramento/Bay Area, CA
Wirelessly posted (8900b/MR2 Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 7.11) UP.Link/6.3.1.20.06.3.1.20.0)
INTERFERENCE W GGCC
Are they adding a third channel to this area? Or was this something else?
commstar
PW WRG698
CALIFORNIA, STATE OF
[OFFICIAL DUTIES OF THE STATE OF CALIFORNIA]
Control Point 1 - 3165 GOLD VALLEY DR, RANCHO CORDOVA CA 916-657-9999
(link)
04/28/2009 License Modified
1 - PINE HILL END OF PINE HILL ROAD (PINE HILL 1, T3 #8647--CAN), RESCUE (EL DORADO) CA (map)
42.34 FB 100p 794e 20K0F3E
42.46 FB 100p 794e 20K0F3E
44.84 FB 120p 48e 20K0F3E
42.54 FB 100p 100e 20K0F3E
44.66 FB 120p 85e 20K0F3E
45.36 FB 120p 85e 20K0F3E
avtarsingh
Cyberspace
when you hear the blue and its traffic from another channel its USUALLY 1 of 2 things
1-if staffing allows or requires a dispatcher for the blue - and the usual operator for gold black whatever goes on break bathroom etc - and the blue dispatcher covers calls for him her ..sometimes they forget and they have blue and gold at same time - kind of a simulcast
or
2-they forget and make an oops
the 45mhz channel is going to be a new blue-2 channel from the chppers chp enhanced radio system
in their infinite wisdom - the state pursued licenses for an extra blue channel on 45mhz instead of finding a channel on 42 mhz - so now the vehicles (when in place) are supposed to operate 3 mhz wide
a nice feat for a low band mobile antenna
k6scm
New CHP Frequencies - Anyone have info?
Near as I can tell here's the way CHP is currently configured and some recently added new additions to the Sacramento Dispatch Center's regional coverage scheme.
MOBILE EXTENDERS (All HT's/CAR Rptrs.): 154.905 MHz (CSQ)
SOUTH(#112) / EAST(#58) & YOLO Co. (#47) Co. Black Ch. - 42.46/42.70 MHz (PL 179,9) 75.96 MHz (PL UNK.)
Newly licensed unidentified CHP base 44.62 MHz
Newly licensed unidentified CHP base 44.66 MHz
Newly licensed unidentified CHP base 44.84 Mhz
NORTH(#46) Gold Ch. - 42.12/42.20 Mhz (PL 179.9) 72.46 MHz (PL 146.2)
Newly licensed unidentified CHP base 44.84 MHz
PLACER Co. (#45) / NEVADA Co. (#42) / EL DORADO Co. (#44) - Green Ch. 42.54/42.24 MHz (PL 179.9)
Newly licensed unidentified CHP base 45.36 MHz
STATEWIDE (Any/All) Blue Ch. - 42.34/42.18 MHz (PL 179.9/CSQ)
LIME TAC-6 45.06/42.38 (PL UNK.)
CAPITOL/CENTRAL DT SACRAMENTO (State Buildings) 453.200 MHz (PL 127.3)
CAPITOL/CENTRAL DT SACRAMENTO (State Buildings) 460.375 MHz (PL 127.3) (* sometimes patched to Black Ch.)
All can be patched to the Sacramento Regional Radio Communications System public safety TRS via Talkgroup 63920 (CHP Patch/Interop) when activated.
Besides the 72/75 MHz links, the rest are microwave or land-line to the mountaintops. Anyone know what these new 44 & 45 MHz frequencies channel color/use designations are?
P.S. Look for 700 MHz coming in 2012 (if they don't run out of money before then).
tcomm_specialist
Sacramento
The Rancho Cordova Area is to relieve pressure from the burgeoning Sacramento/El Dorado County Area and provide faster response times...Prior to the RCA officers either came from Mack/99 or Placerville to respond to East Sacramento/El Dorado Highway 50 area...now they respond from Rancho Cordova...much closer for those inevitable shift change calls...I am not exactly sure what the boundaries are I haven't had a lot of contact with the RCA officers yet...the one I spoke to said it's Watt&50 to Shingle Springs and the area adjacent to the freeways in Sac County and all of El Dorado County West of Shingle Springs...at the time we had that discussion this was still an "experiment" and the borders were not finalized...seeing as there is a 44MHz license at Pilot Hill I would guess that they may add another channel...Black can get very busy with South Sac and Woodland at times...another interesting side note is the coverage issues with Gold in North Sac...so there may be some changes there...the CHP is working to revamp their system to include new HT/Extenders...all though I am not privy to all the details...I did see a presentation regarding that endeavor...
cousinkix1953
San Louis Obispo was another CHP station that used the blue channels in the early 70s. They switched to 42.12 / .20 later in the decade...
RolnCode3
Saturday morning I talked to two CHP officers at a crash site (I stopped by while they were still enroute, then BS'd while they did their thing). They said the Rancho Cordova office is being disbanded, and they are moving out of Rockingham station back to the South Sac office (Massie Ct.) They told me this is the shortest lifespan for an area office, ever. Got to do a good checkover on the new Whelen lightbars as well (which is far more interesting to me).
Mike_G_D
Vista, CA
Avtarsingh,
I still maintain that, at least from a theoretical and practical design perspective, a properly designed commercial public safety oriented quality radio should handle the SWR you will likely see from that spacing with little problems. Now, I cannot speak for the actual radios being used as i do not know what their internal design specifics are, however, I do know that a design for a final amp able to handle high or medium high reflected RF energy is quite possible and one need only specify the constraints and go from there. I simply cannot imagine that the radios used in the CHP vehicles are weak in this design area.
Also, from an earlier post, it was confirmed that the low band antennas used on the cruisers in at least one area are designed to yield a high usable bandwidth. I can't recall what the post said exactly and am currently too lazy to go looking for it but I think the band width was something like +/-5MHz. That's pretty good for a low band loaded whip and is certainly adequate for the spread of frequencies used in the current (new) CHP radio system assuming we are talking about an SWR of no worse than, say, 2:1 at the limits. I cannot imagine that the radios are so weakly designed so as not to be able to handle at least a 3:1 VSWR at their rated power outputs and rated duty cycle. Concerning the whip design, if you are working with a loaded whip shortened relative to the center design frequency wavelength, one thing you can do to improve the bandwidth is to use very high quality conductive material for the loading coil construction and make the coil as large as practically possible (in terms of the diameter of the coil wire). Doing so will increase the effective usable bandwidth of the antenna around the center frequency design point (Fc).
Again, if you know your system operational characteristics, nearly anything (within practical limits) can be designed to handle normal usage within those constraints and usually a good error margin is employed to allow for considerably harsher constraints that may be encountered. Know the normal power output of the transmitter, know the normal duty cycle, and know the expected worse case VSWR to be encountered and simply design accordingly. I am not saying it is done, in the CHP radio system sense, since I don't know but I am saying it certainly can be done and is quite practical!
As for the frequency spread of the new low band CHP system and the overall approach to using it, I rather think it is cleverly designed. Consider that the system as a whole, like nearly all LMR systems employing dual frequency base/mobile designs, is optimized for the mobile transmit-to-base frequencies' best efficiency. This is only logical as it gives best performance where needed - for the base to hear the mobiles. The new CHP system has at the center the 42MHz frequencies which, it looks to me like, are being made into the mobile-only portion of the spread. I say this because It looks to me like their ultimate goal is to move all base transmitters off of the 42MHz frequencies to reduce high power base transmitter interference to much lower power mobile sourced signals. Again, a very logical choice from an RF system design perspective! Now consider that the newly acquired base transmission frequencies are spread out at a nearly equal offset from the middle mobile-only (at least future mobile-only) band. The 39MHz channels are as far in frequency spread from the middle mobile band as are the 45MHz frequencies. Obviously the 44MHz channels are closer but not enough to cause difficult interference issues and are still more than enough in terms of spread from the center mobile band to ease duplexer and isolator design at transmission sites. Once again, very logical and well thought out. Next, consider the problem of acquiring frequencies from a limited pool and maximizing their effective usage. There are only so many available channels within a 1MHz spread given a standard 20KHz channel spacing (which it is in the US LMR low VHF range for non-federal part 90 operation). So, adding in more high power bases in amongst relatively much lower effective power mobiles would be very problematic. Now you could argue that they could have placed the mobiles at the ends and the bases in the middle but you then encounter two difficult issues. One, you end up having more mobile frequencies than base frequencies which means less base output choices; it's far harder to design for effective geographical frequency reuse when dealing with high power fixed stations (most especially considering the very long effective coverage when dealing with frequencies in the low VHF range) than it is to design for the same issue when dealing with relatively low (effective) power mobile transmitters! The second problem with this is that the VSWR issue for the mobiles becomes more difficult in that mobiles would be limited to the extreme end of the system band for the area they are in and would be forced to deal with a worst case situation in terms of reflected RF in potentially more numerous circumstances given that they may need to communicate on channels with mobile transmit frequencies in either the 39MHz band or the 45MHz and to do so for the most important design element of the system - the stations' need to hear the mobiles under the worst case conditions! Now you have high VSWR and lower effective transmit energy efficiency on the mobile transmit channels when a mobile is forced to transmit on a channel on the opposite side of the system band from the one they normally use while attempting to communicate with a base station - the most important element of the system design!
By devoting the middle 1MHz wide 42MHz to mobile only use and giving base transmitters three 1MHz wide bands of channels nearly equally spaced out from the mobile band you have made the best possible compromise in terms of giving the most channels to the high power base transmitters while allowing effective reuse of the more limited number of mobile channels. Also, you have done the best practically possible to limit the VSWR issue for the mobiles as much as possible given that they need maximum transmit efficiency when transmitting to the base station on only one contiguous 1MHz band as opposed to being forced to do so on two bands located 6MHz apart in the worst case! In addition, you have made life far more easy for the base transmission site designers and maintainers because they can place mobile receivers and base transmitters much more effectively (they can be closely spaced now, even co-located, if need be) given that they no longer have to deal with high power transmitter frequencies being within the same 1MHz segment as receivers needing to receive very low level and dynamically varying level transmissions from distant mobile units!
Personally, unless they were to leave everything as is or was in terms of simply leaving bases and mobiles all on one 1MHz wide swath of channels, I think they (the state radio system designers responsible for the new CHP system) did a very commendable job of making the right design choices and limiting the overall number of compromises! And if they were to keep everything on the 42MHz band then they would be right back to where they started in dealing with the limited number of expansion capacity in a geographical area that is growing rapidly in terms of the population! Even considering narrowbanding which is not required on the US VHF low band (as far as I know) yet, that would only give you so much in terms of more channels and would not solve at all the problem of geographical co-location interference issues between base transmitters and mobile receivers nor the problem of interference issues between bases in geographical frequency re-use terms.
Sorry avtarsingh, I simply do not agree with you on this. All manmade engineering designs contain compromises; effectively limiting the compromises to the lowest number and lowest impact is the best we can do. This is all the more true for a very large statewide radio system! Again, I personally think that the state radio system designers did a good job on designing a new system given the constraints they had (staying on VHF low band, getting three new 1MHz bands of channels (though down here in San Diego County we have had 39MHz full-on repeat for several years now) centered around the original 42MHz band, and dealing with a very large number of mobile units that may need to effectively operate well outside of their normal day-to-day operating area) and applaud them for it!
Now I am only speculating when I say that the 42MHz band will become mobile only but I see strong evidence that that is what the system designers are at least shooting for, at least eventually. It sounds to me like the most logical choice to make with the frequencies and band they have to work with.
From the content of your posts it seems to most of us that you are in some way connected this effort from a technical standpoint. I can understand why you may be reluctant to say if this is true one way or the other, of course, but if you are close to the technical elements of the system design (either in the maintaining of system elements or its design) you would, therefor, be likely to have access to design documents as well as access to the designers themselves and other related technicians and engineers. If true, I strongly suggest that you read those documents and speak to those other technical folks who are involved and ask them about your concerns and criticisms. See what they have to say for themselves! I rather expect that you may find answers which reflect much of my speculation and opinion as I so wrote above.
-Mike
avtarsingh
Cyberspace
without even looking at forward / reflected power you can tell simply from listening that the radios are NOT WORKING as they are supposed to
this means 1 of 2 things
the ranger rx needs to be retuned to allow for better rx on 45 mhz (i havent worked on rangers enough to know if the RX needs to be retuned when moving 3-4 mhz away from the primary programming) the radio gets its programming through serial lines from the head which tell the radio what freq to park on
i would assume taking the radio and putting the programming 3 mhz away would affect the rx sens if it hasnt been retuned (assuming it needs retuning) this is an 1980s-1990s era radio anybody who has worked with radios from that era know that freq rx had many filtering coils to tune in it .. the ranger not sure? if it does this is causing their crappy rx sens in the field
OR
the antennas are not efficient
listen to a blue air op - a mobile cannot even talk on TA more than a few miles away NOW
i can listen to an airop up the hill (gold run etc) and cant hear any of the mobiles AT ALL!! when they were using 42.34 i could hear the mobile units at the unsquelched level about a .15-.20 level now i cant even hear them nothing changed on my end a sweep of my antenna shows nothing has changed on my end
prior to the 45mhz shift it was very common to hear chp mobiles 10-15 miles away[flat ground] (with my home antenna system ) and as far as higher elev terrain it was common for me to hear gray mobiles (truckee from sac) i never hear them anymore very rarely and i am sure hes in a spot thats a clear shot to the valley
you can see the non stop problems many are having
non stop problems with mobiles not being able to hear etc
SOME (and i mean a very small %) is being caused by radar units overheating and creating noise deafening the rx on the ranger
the wide band low band antennas were used in CERTAIN areas because they had 39 and 42 mhz channels which req the wider band antenna
but AGAIN the majority of chp patrol cars have an antenna that only has about 800khz of bandwidth
you can clearly see it on an ifr7550
and for the last 2-3 years the majority of patrol cars rolled off the line with 800khz antennas tuned for 42.34 so do 400 khz on either side
yes the PAs can withstand high reflected power.. but not forever
any isolator after repeated abuse will fail prior to the shift the ONLY time a radio would see a bad swr was if the antenna or feedline were damaged
so imagine a unit with a 42.34 800 khz antenna sitting on 44.84 talking on the output to the air unit for an hour or more ???
now listen to chp for any amount of time and you will see a LOT of talkaround traffic this is exponentially causing harm to the isolator and its a matter of time and it will fail
you are trying to apply a wideband antenna theory to all patrol cars and it doesnt work because only a small % have them
a senior tech downtown brought this up to engineers .. rx sensitivity retuning and narrow bandwidth antennas and it got ignored because the "new " radio system is coming along
and someone posted about chp going to 800
chp is NOT going to 800
they are merely getting portables "some day" that have 700 and 800 for the avr and other good stuff
you mentioned about the 3mhz spacing we all know why chp moved to this
but you asume that the officers are parked on and only xmit on 42 mhz
for many officers they spend more time on talkaround than they do talking to dispatch
i hear many who sit on channel 2 (talkaround) the whole shift
we have all heard the dispatcher say "copy your traffic on 2"
Sac916
CHP and SRRCS are currently working on a permanent patch to SRRCS talk groups - CHP will use a dedicated channel that is patched to a dedicated SRRCS talk group. The MOU process has started and hopefully will be operation/implemented before summer.
RolnCode3
Booyah! Long overdue, and most welcome. Great idea to whoever started it.
