CHP Los Angeles issues
FrensicPic
Los Angeles
From the West San Fernando Valley I am reliably copying LA Comm Center: TEAL2 (of course), TAN3, BROWN2 and BLACK2. Copyable but weaker signal YELLOW3, PINK2, ORANGE3, GOLD2. I can also copy PURPLE up in Moorpark; and GRAY1 down in Westminster.
BCD996P2 with a VHF-High 1/4 wave ground plane outdoors at 20 feet.
Los Angeles County / Marin County, CA
I'm using a BCD325P2. It's not that I can't pick anything up, it's just I can ONLY pick up East LA (yellow 3)
ladn
If you have the channel programmed with a PL tone, try taking the tone out.
Besides CHP (which is low band) can you receive anything else like NOAA weather (162.550)?
hill
Middle River, MD
Low Band is hard to receive on a little handheld scanner antenna. You something like a mobile antenna for this band or a ground plane antenna up high at home.
I would expect with your setup to only to be able to one or two on the closest divisions.
Gotcha. I’m located in Studio City so would yellow 3 be the channel for that area? Not really familiar with station jurisdictions.
gmclam
Fair Oaks, CA
You need a suitable antenna to pick up (VHF low band) CHP unless you have great "line of sight".
Randyk4661
Garden Grove, CA
I've noticed that CHP radio isn't what they used to be a few years ago.
Here in the OC it's hard to hear the local stations.
markclark
Nevada Range
You're in West Valley Division (56), right on the west border of Altadena Division (98).
Also plug in the Southern Blue for pursuits and other events. You really need at least a low band rubber duck for decent reception. An outside antenna cut for low band is best. You don't need to bother with the PL tones at all.
45.52000WPAE678RM186.2 PLTEA2 SOU Teal 2 - West Valley (56)
44.74000KJP457RM186.2 PLBRN2 SOU Brown 2 - Altadena (98)
45.42000KMD770B136.5 PLBLU2 SOU B Blue 2 - Base
marcotor
I ♥ÆS Ø
Sunny SoCal
Really? From where I am in Yorba Linda (about a mile West of the Nixon Library), CHP sounds about the same as it has over the last 15 years I have been in the city. Santa Ana, Westminster, San Juan Cap, Baldwin Park, Altadena, Riverside and of course the Blue all boom here. I don't listen much to the other LA Commcenter channels, but they have been good to great with my little peanut whistle antenna 15' in the air.
PaulNDaOC
I have a 325p2 and reception improved greatly when I programmed the freqs as wide band.
d119
Patch & Channels Clear...
EM1's guest house.
As it should. Narrowbanding affected 150-174MHz and 450-470MHz (with some exceptions, and of course the matter of T band).
Lowband never went narrowband, so it should sound correct in wideband mode.
radiochuck
Traffic Reporter
Phoenix, AZ
I never had good results while trying to monitor CHP from a vehicle without an outside antenna. A CB antenna works pretty well for me.
