CHP units with NO low band antenna
E5911
the lower desert
So this morning, I saw the second unit from CHP with NO Low band antenna. Both vehicles were Tahoes and neither had a low band antenna. Are new patrol units coming out of Sac with no low band radio because of CRIS?
DMS11B
Closet Nerd
Cali
No, lowband ain't going anywhere any time soon, typically removed for maintenance or washing
The radio head showed 4 RF decks, so unless they doubled up on one of the bands, it looks like it's got low band capability. Since these are supposed to blend in a bit more, ditching the standard low band whip might be part of the plan. The front passenger fender antenna, as DMS11B mentioned, looks a bit long for stock. Might be some StiCo variant.
AM909
Radio/computer geek
SoCal
That's absolutely lowband, without question. You see the same thing on unmarked staff vehicles. It's a Sti-Co. They are also extremely narrow bandwidth.
Yeah – it's almost certainly a Sti-Co fender disguise that's custom-engineered for them to handle the 39/42/45 MHz setups they use (even in the same areas!). That or they are just tuned for one office's mobile channel, and there's enough power radiating on the base freqs to compensate for the antennas being somewhat detuned at the RX freq. Low-band is bizarre.
chrismol1
P25 Trucking!
Yup, a fender antenna is out of place on probably least a decade on modern vehicles, is HUGE! Way above the roof line!
AM909
Radio/computer geek
SoCal
Will vehicles with the same colour of the pavement be in more crashes?
I think the Czechoslovakian VB had it right with the white and yellow paint on the cars.
Yup. It's about visibility (reflectivity), with black being about 10% more risky than white.
I like how they admit the dark colors are about being stealthy. :) We used to call them slick-tops, though the ultra-flat light bars in recent years have blurred the distinction.
INDY72
Indianapolis, IN
Plus all the rooftop ants are lo pro, can't tell bands unless you're up close and personal. Surprised there isn't a lo band lo pro ant yet, heck Unication has lo band G series that you can't tell it's lo band without being told. Same stubby ant. The days of porcupine mobiles are long gone.
KevinC
Encryption
I'm everywhere Focker!
Kind of hard to cram nearly 70 inches of antenna into a low profile mount and have it work worth beans. The pagers work usually because base station transmitters run a few hundred watts. With the CHP using it for two way, low profile is kind of out.
Back in the day we installed lo band "transit" antennas on school buses. No idea how they worked out for the ISD, but you definitely needed the real estate of a school bus roof for them...and we couldn't check SWR inside the install bay. We had to be outside, way outside away form anything.
If I remember correctly they only about 6" tall, but 4' long.
Right, I think those were an Antenna Specialists product. Similar design as their locomotive antennas. Long low aluminum cast piece with a funky feed point.
Given the option, the StiCo is the better approach.
